Question about IDEAL MCM TESTER GFI CIRCUIT
Fixing a hot/grd reverse sit.
Pluged a staple gun in outlet,gun jamed,outlets feld to work,tested outlets ,tester shows hot/grd reverse the problem.
  • Anonymous Mar 24, 2014
    what causes this issue on a blank face gfci?
  • 5,245 Answers
1) Copy following links for correct wiring illustrations:
http://waterheatertimer.org/images/Outlet-polarity-200.jpg
http://waterheatertimer.org/images/Wire-2-outlets.jpg
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Add a comment dec 2012, for more help
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Dec 13, 2012
2 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: Understanding Outlet Circuit Test Results
open ground=ground wire (green) is not connected to the circuit box ground or to the earth ground.
(there should have steel rod place in the ground by the local electric company, and gtound wire is connected to that rod).
Open Neutral= same as open ground. unless you are testing 240V, which have 2 hot (110v) and a neutral (0V).
Open Hot= open 110v line (black)
hot/ground reversed= if you understand the above, then this sould be self explaintory.
same a hot/neu. reverse.
if you don't understand how electric wiring works, My suggestion is to stay out.
Posted on Dec 30, 2008
Outlets do not work, circuit tester says Hot/ground reverse but all connections appear correct, circuit is on an arc arrest breaker.
Move wires to different breaker with same amp rating?
Try different tester?
Test wiring box-by-box to locate the reversed connection.
http://waterheatertimer.org/Basic-house-wiring.html#loose-wire
Check each box for Hot and neutral:
http://waterheatertimer.org/Basic-house-wiring.html#test
Gene
Nov 11, 2014 | Electrical Supplies
Why does the unit beep after it is pluged in.
Most new window units have a ground fault circuit. More than likely, the outlet you are using is Not grounded or the Neutral and Hot side are reversed. They make a tester you can purchase at most home improvement stores. I would go buy one and test the outlet. You could have other outlets with the same problem. You have to use a 3 wire outlet. Large side of outlet=neutral, small side of outlet=hot, round or arched hole=earth ground.
Jun 12, 2014 | Frigidaire FAM187S2A Air Conditioner
How to fix hot/ground reverse outlet
The black and the white wires on those plugs are reversed. Turn the power off for those plugs, and swap the wires. The black wires go to the brass colored screw, and the white wires go to the silver colored screws.
Jun 01, 2013 | Electrical Supplies
We have just moved a freezer and pluged it in but it doesnt turn on. it is pluged into an outlet with power i tested that
The Danby freezer(DUF808WE) doesn't work from yesterday, even proper plugged in?
I already check electrical outlet. How can I fix it?
Jul 08, 2011 | Danby Freezers
We are trying to install a Leviton No. T5225 Combination switch and tamper resistant outlet. We are replacing the single light switch with this new one. We have a red, a white, and a black wire. When we...
You are installing a combo device with switch and outlet.
The outlet is tamper resistant so a child cannot stick a key into outlet and get shocked.
For the outlet to work, a 2-prong plug must be inserted.
Wiring the device:
Electricians don't guess, they test.
Device has different colored screws: dark, silver and brass.
Separate wires for testing.
Do not unwind wires that are twisted together.
White wires that are twisted together and located in back of box are included in testing.
Use ordinary 2-lead tester.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire connects to dark screw.
Hot is identified.
Test Hot wire to all other wires, except bare ground wire.
Tester lights up on Neutral wire. Neutral connects to silver screw.
If you do not have a Neutral wire, then outlet will not work for that location.
You can get the outlet to work by connecting bare ground to silver screw, but that is violation of code.
Last wire goes to Load (light, fan, motor).
Load wire connects to brass screw.
In your case, this is red wire.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 19, 2011 | Leviton 8299 Combination Switch / Smart...
I can't seem to get my T5225 combo outlet to work. I connected it as directions said but only the light switch works, I tried changing it around & the outlet only works when the light switch is turned...
Remove device.
Use ordinary 2-prong tester.
Tape wood sticks to tester leads to keep hands away from power.
Turn on power.
Tester will light up on Hot wire. This wire connects to dark-colored screw.
Hot is identified.
Now test Hot wire to each other wire in box, including white wires in back of box (exclude bare ground wire)
Tester will light up on Neutral wire. Neutral wire connects to silver screw. This will complete circuit to receptacle part of device.
The last wire goes to Load (light). This wire connects to brass-colored screw, and will complete circuit to light..
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps shown above for a price.
Dec 24, 2010 | Leviton 5225WSP Switch and Outlet
Our home has a outlet that keeps blowing the breaker
you have to reverse it and call an electrician for help...or better yet replace the breker fuse to a higher amperage,or change the wire size or rewire it and install a new breaker with a higher amperage....have a nice day!
Feb 03, 2010 | WELA electronic Ge Smart Home 8 Zone...
What does open neutral on my gb circuit tester also hot/ground reversed mean
An open neutral means that neutral, or common wire is not connected somewhere. If for example you test a outlet in a room, and the tester shows that you have an open neutral, Then somewhere along the circuit the neutral is not connected properly. In rooms most outlets are connected in series to each other, so if you have an open neutral in one outlet, it can affect all the other outlets too.
Hot/ground reversed means that the hot wire and the common wire are installed in the wrong order.on the outlet,you have a hot side (black wire)and a common side(white wire)and the hot wire is installed on the common side instead of the hot side and the common is installed on the hot side.This show up on the tester this way because the common and ground tie into the same bar in the panel.
Fix the open neutral first as this can show incorrect reading on the tester on all outlets after the open neutral.
Aug 03, 2009 | Gb Electrical Electrical Supplies
Dec 27, 2008 | IDEAL MCM TESTER GFI CIRCUIT
IDEAL MCM TESTER GFI CIRCUIT Logo
156 people viewed this question
Top IDEAL Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Gene Haynes
Are you an IDEAL Electrical Supply Expert? Answer questions, earn points and help others
