Question about Technics SH-GE90 Home Equalizer
Technics SH-GE90 DSP gives off high pitch sound, no display in the window,only the red dots down the side and the demo button dose not change demo modes.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 99 Answers
Check power supply capacitors.
These are prone to leakage on the SH-GE90 and can cause various
symptoms such as no display or in some cases a flickering display.
Posted on Mar 25, 2013
5 Suggested Answers
SOURCE: 1. The dislay flickers too
yes there is a diode its looks the same as d714 but with a black stripe take it to your local parts shop and show them the diode and say i need 1 with a black stripe and hope this helps good luck all the other diodes have a white stripe apart from that 1
Posted on Jan 25, 2011
rommelalilin
  • 2178 Answers
SOURCE: I have technics reciever sa ax 6 (without tape
Click here.
Posted on Nov 23, 2010
  • 99 Answers
SOURCE: the dislay flickers SH GE90.technics .it seems to
replace the 3 electrolytic capacitors in the power supply section near where the lead from the transformer connects to.
they're sat side by side.
you may notice only 1 might be leaky but replace all 3 for good measure.
i've had quite a few with exactly the same fault and all were cured by replacing the above.
hope this helps?
Posted on Jun 29, 2010
  • 4234 Answers
SOURCE: I bought SH-GE90 DSP And I pluged into 240V source
It is not possible for us to be able to determine the extent of the damage. It is possible that only the fuse has been damaged. It is also possible that the rectifiers have been dmaged. The bottom line here is that there needs to be some examination of the unit and some testing of the internal components. The best case will use parts in the $5 range. Worst case you are looking at $50 or more in parts. If the cost is not too high, take this to a servicer and ask for a detailed repair estimate.
Dan
Posted on Dec 19, 2010
Good day...My unit works 100%...i just wanna know why the two vertical red lines on the display flashes. Never did it before. Any reason for this ?
The 2 larger power supply capacitors need replacing.
These are prone to leaking on this particular model and cause
the display to flicker.
Depending on how bad the leakage, if you take the lid off you
may see evidence of this around where the power transformer lead
plugs into the main PCB.
Aug 18, 2011 | Technics SH-GE90 Home Equalizer
MY technics SH-DV290 AMPLIFIER is always in demo mode any ideas about turning it off.
Turning DEMO off
A demonstration of the display is shown if you have not set the clock.
You can reduce the power consumed in standby mode by turning the demonstration off.
While the unit is on:
Press and hold [-DEMO] until "NO DEMO" is
displayed.
Each time you press and hold the button:
NO DEMO (off)9DEMO (on)
The 'Demo' button is on the left hand side of the front panel.
Jan 25, 2011 | Technics SC-DV290 System
I bought SH-GE90 DSP And I pluged into 240V source while the indicator was on 110v and now its not working will replaceing the transformer will help or it just simply gone.
Dan
Dec 02, 2010 | Technics SH-GE90 Home Equalizer
I will be upgrading my av receiver soon. The latest editions seem to have an in-house equalizer feature. Should I still use my Technics equalizer, which will give greater benefit ??
If you use the amp for music most of the time I would certainly keep the older eq as I am assuming it is most likely a good quality analog device.
These modern ones are almost all digital and are not as nice or easy to use and probably introduce latency to the signal path. Sound is all about what you like and I would bet that you will prefer the older analog sound over the new digital version.
I am not sure exactly how this would affect the other uses of the new kit such as cinema etc.
Hope this helps Thanks for using FixYa.
Aug 17, 2010 | Technics SH-GE90 Home Equalizer
I have a Technics Stereo graphic equalizer. Trying to find out why it's not getting any power. it has no fuse inside. I hook the plug into the outlet and nothing. atleast the light on the equalizer does...
The power supply unit has failed in your equaliser. If it is the main transformer check for the continuity of the primary and if open you will need to replace with the same one or rewind with the same parameter.However if the thermal fuse is blown you can short the winding with a fuse wire. Also check on the dc side for any fusible resistors that would have opened out. Hope you check this out. Good day
Aug 03, 2010 | Technics SH-GE90 Home Equalizer
The dislay flickers SH GE90.technics .it seems to be a common fault.. can this be fixed
hope this helps?
Mar 11, 2010 | Technics SH-GE90 Home Equalizer
USER MANUAL NEEDED
Hi - You can download the manual from the link underlined in blue below:
SH-GE90
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Technics SH-GE90 Home Equalizer
Technic's 1210M5G problem with the pitch slowing
Sounds like your pitch control is about to go bad. I would suggest replacing it. The part can be purchased HERE.
- TERMiNAL OPTiC
www.DJPROLAB.com
Feb 25, 2008 | Technics SL-1210M5G Turntable
Technics SH-GE90 Home Equalizer Logo
422 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
