Question about Electronics - Others
I want to reformat my sandisk micro mini sd card using my verizon lg
  • 2,072 Answers
You can't, fdisk on Android phones has had that ability removed. Buy an usb to micro mini card adapter and format it on a computer. Much easier.
Posted on Dec 25, 2012
SOURCE: Micro SD 2 GB just stopped working
I had this same issue added music to my card did a safe remove from my comp. placed in phone and it stated "No memory card inserted" and wont read in adapter in computer Im so Sad i lost all my pics/memories :( it just means that the Card is Fried (Burnt Out) no way to fix this their just like SIM cards In 3G phones and if the copper bars get scratched or bent just the slightest bit it kills the SD card.
Posted on Oct 29, 2008
  • 119 Answers
SOURCE: problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
The problem is that a 4 GB micro sd card is HC (High Capacity). You will need to buy a card reader that can read HC micro sd cards (cost +/- € 8).
Very important: check if your mobile phone works with high capacity micro sd cards because a lot of phones don't work with HC micro SD cards.
Don't forget to rate, thks
Posted on Jan 08, 2009
SOURCE: micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Posted on Feb 10, 2009
bfready
  • 149 Answers
SOURCE: My PC will not recognize my 2GB Micro SD Card
Does the PC recognize the adapter when you place onto the USB port? If not, try another USB port. It should atleast say it has detected hardware, see if it's finding and installing the drivers correctly.
If it's not the adapter, could you reformat the microsd card? Perhaps, it is corrupted? Is this SDHC or SD (what capacity). Older Blackberries do not support SDHC (I believe this is 4gb or above), perhaps this has something to do with it.
I hope this helps,
Bill
Posted on Sep 04, 2009
SOURCE: i ve forgotten password of my 2gb sandisk micro sd
mico sd card 2 Gb san Disk card not format
Posted on Apr 15, 2010
Why isn't my LG phone recognizing my Micro SD Card any longer? How can I put music on my phone than?
Try another known working card in the phone. If that also does not work then you have a serious issue with that phone. If it works then parhaps your card has gotten corrupted and needs to be reformatted or replaced.
Aug 30, 2015 | LG Cell Phones
Undoing Write Protection On A Micro SD Card
These cards have a switch on them to protect them just change the position and you should be able to format it.
Jan 15, 2013 | Samsung 8GB Sandisk TF Micro SD Card Black
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
Is a Micro SD (HC) card compatible with the LG Env 3?
Verizon offers a 16GB Micro SD(HC) card that it says is compatible with the LG ENV3 Cell phone so the answer would be "yes."
Apr 04, 2010 | LG enV3 VX9200 Cell Phone
Cannot copy anything to Memory card in LG Viewty
reformat your card through your pc. don't go for quick format. if it doesn't works after that also then get a software 4 low level formatting. if then also it doesn't works ask me again.
kindly rate my solution.
Jun 25, 2009 | LG KU990 Viewty
Micro SD not reading
If you are unable to access/view the contents of the card, chances are, it needs to be reformatted for it to work again, which means, data will be loss. You may, however, try to search the web for a data recovery program which you can first try to use before reformatting the drive.
Feb 17, 2009 | SanDisk 2GB microSD Memory Card
Where do you put the sandisk into?
the micro SD(smallest) goes into the phone the other 2 are adapters, mini for older PDA's, the largest goes into your PC (usually on newer models), if the pc does not have a slot for the sd, use a usb adapter to transfer music
Feb 14, 2009 | LG RUMOR Cellular Phone
Micro sd card not working
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
How do you reformat a 1gb Sandisk Micro SD Mobile Memory Card? The phone I am attempting to reformat the card for is the AT&T Quickfire.
Normally you should have an option on the mobile for reformatting if not you will have to use the adaptor & format it on the PC
Jan 05, 2009 | SanDisk Memory Media
Electronics - Others Logo
47 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
