Question about Canon P23-DHV Calculator
Tring to subtract
I want to subtract I press on the number then the subtract and the next number and the = and it does not subtract If i press on the add number it will
  • chickman Jan 19, 2009
    I cannot get this problem solved, either. Seems simple, but isn't.
  • Anonymous Mar 12, 2014
    how do i just subtract without a negative symbol coming out in front of the number. I just want it to act like a regular calculator
    Problem Solver:
  • 6 Answers
With an adding machine, which is what this is, you enter the number followed by the + or -. If you wanted to add 10+20, you would enter 10 then + then 20 then +. This would show your answer. If you are using the printer and you wish to see the final answer on the paper, hit the * key and your answer will print.
If you are subtracting, let's say 100-40, you would enter 100 then + then 40 then - then *. Adding machines expect you to enter long strings of numbers to total. You may have both positive and negative numbers. So, you always enter the number first followed by either positive + or negative -.
You might have 100 + 25 - 37 - 1 + 50. For that enter:
100+25+37-1-50+ then *
Different than a calculator but the same for all "adding machines". This machine should really be called an adding machine since that is the kind of input it is looking for.
Posted on Feb 04, 2009
How do I create an Excel formula to subtract within a column, row by row?
put in result row
=A1-A2
or = A1-A2-A3
A being the column
the numbers 1 2 3 are the rows
or go to result cell type =
then click on cell then press -
then click on cell to minus then press -
the click on next cell to minus
Dec 08, 2016 | Computers & Internet
How do you simply add/subtract on a HR-10-TM Casio mini desktop printing calculator?
the function buttons are labeled + and -
to add put in the number then press the + button then put in the next number and + and son for all the numbers you are adding up
to subtract put in a number then press the- button ,then put in the next number and press the - button and so on
to do a combination calculation put in a number then press the + button and so on until you come to a number that you want to subtract in which case you put in that number then press the - button and if the next number is to be added ,put the number in and press the + button
Oct 22, 2015 | Casio Office Equipment & Supplies
What do i set it on to add and subtrack
To add, turn the calculator on and enter the first number. Press the + key and enter the next number. Press the = key and see the result.
To subtract, turn the calculator on and enter the first number. Press the - key and enter the next number. Press the = key and see the result.
Feb 07, 2015 | Casio Office Equipment & Supplies
What is 67,872 divided by 24, step by step?
First, find out how many whole times 24 will go into 67
67/24 = 2 with a remainder that we don't care about. Write down 2
Next, multiply that answer (2) by 24 2 X 24=48
Subtract that 48 from 67 67-48=19
bring down next digit (8) append to the19 198
divide 24 into 198 198/24=8 Write down 8
multiply that answer by 24 8 X 24 =192
Subtract that 192 from 198 198 - 192 = 6
bring down next digit (7) append to the 6 67
divide 24 into 67 67/24 =2 Write down 2
multiply that answer by 24 2 X 24 = 48
subtract 48 from 67 27-24=19
bring down next digit (2)append to the 19 192
divide 24 into 192 192/24 = 8 Write down 8
multiply that answer by 24 24 X 8=192
subtract 192 from 192 192-192=0 You're done!
Your answer is the numbers you wrote down after the divisions = 2848
2 8 4 8
24 ) 67872
- 48
198
-192
67
- 48
192
- 192
0
Oct 15, 2014 | Office Equipment & Supplies
Answer always appearing
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."
If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.
Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
Sep 23, 2013 | Texas Instruments TI-84 Plus Calculator
I do not have the manual. If I want to add or subtract do I put the total amount in and than hit the plus or minus key ? i.e., $128,000 -10000. do I hit the minus before the amount or after? -1500....
You can download the manual from
http://downloads.canon.com/cpr/software/calculator/P170-DH-(USA-HWB).pdf
128000 - 10000 then press = or chain the calculation by pressing + or - and the number you want to add or subtract.
Sep 30, 2010 | Canon P170-DH Calculator
How to add figures and then subtract from a larger number
use the + key after each number to add the total will appear on screen. When all numbers have been added, enter number to subtract and then press - key. The subtracted number will appear in read on the paper (if two color). and then press the star key to get total.
Jul 08, 2010 | Canon P23-DHV Calculator
I am unable to subtract
The way to do math on this calculator is a bit different than on others. To start off, when doing subtraction, you must press the + key. This tells the calculator that you are working with a positive number.
Say you have $588.43 in you check book but you spent $136.92. The buttons you press on the calculator will be as follows:
588.43 + 136.92 -
The positive total of 451.51 will be on your screen. If you are using the print function as a way of keeping track, press # to print the on screen total.
Just remember, enter your first number and hit +. After this, each number that you are subtracting will have a - behind it.
Mar 04, 2010 | Canon P170-DH Calculator
How do you subtract fraction on a caluclator. problem: 6/7-2/5
A fraction is just a number like (almost) any other. On most calculators, as you enter 6/5 the calculator displays its decimal value. When you press - the calculator waits for a number 2 then / then 5. Once you press the equal sign it will calculate 2/5 then subtracts it from the preceding result. The priority rules favor multiplication and division over addition and subtraction.
On some calculators you can keep a fraction in fraction format and operate on it with other fractions, and the result may be obtained as a fraction.
The gist of the story is that ON A CALCULATOR operations on fractions as performed like operations on any number.
Dec 20, 2009 | Sharp Office Equipment & Supplies
How do I add and subtract on this thing?
I do know what calculator you have but on most calculators you have digit keys to key in numbers, operation keys (multiplication, division, addition, subtraction), function keys (log, exponential, %, square root, square or a power) and you have the = key to obtain the result of the calculation.
Press the [ON] button
To add 2 numbers, exemple 12 and 13
12 [+ key] 13 [= key]. Calculator displays 25, or 25.00 or 25.0000...
To subtract
13 [- key] 7 [=key] . Calculator displays 6 or 6.00, 6.0000....
To multiply
32 [x key] 5 [= key]. Calculator displays 160.
You may have memory keys, to store values. They may be labeled M to enter a number in memory, M+ to add a number to the one already in memory, M- to subtract from the number already in memory.
Hope it gets you started.
Oct 10, 2009 | Canon Office Equipment & Supplies
Canon P23-DHV Calculator Logo
642 people viewed this question
old marine
old marine
