Question about Uniden BCT7 Base Scanner
Uniden bct7 scanner doesn't hold memory
Programmed frequencies fail when power goes off
SOURCE: How do I Program my Uniden Bearcat BC60XLT
i am having trouble programing frequencies into my scanner i need help!!!!!!!!!!!!!!!!!!!
Posted on Aug 18, 2008
  • 160 Answers
SOURCE: programming
you can't it's all ready programed
Posted on Nov 05, 2008
smarthome2
  • 1114 Answers
Here's the link for your manual It's 3.71mb http://www.uniden.com/pdf/BC60XLT-1om.pdf . The manual is written for "People" not "engineers" If you still have problems, post a reply and I can help further. Hope this helps
Posted on Jun 02, 2009
audio20
  • 22 Answers
SOURCE: cant program frequencies into my uniden bc72xlt
Just to verify you are trying to program frequencies the scanner is able to receive.
This unit is limited to the following freq range.
25.0-27.995
28.0-29.695
29.7-49.995
50.0-54.0 5
108.0-136.9875
137.0-143.995
144.0-147.995
148.0-174.0 5
406.0-419.99375
420.0-449.99375
450.0-469.99375
470.0-512.0 6.25
If the frequencies your are trying to enter or outside these bands you will get a error.
Next Direct Entry Mode Programming
Press Func. + PGM
Press E to enter ch in current location
To change location pres func + Up ^ or down key to choose location then press E
Enter your freq then press E
Hope this helps.
Posted on Jul 24, 2009
BillB-SA
  • 2761 Answers
SOURCE: how to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
Posted on Aug 16, 2009
Resetting the scanner clearing all memories
Power the scanner OFF. Press and hold the 2, 9, and HOLD keys and power the scanner ON. This procedure will clear all programmed frequencies and return the scanner to its original factory settings.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC340CRSom.pdf
Bill B.
Listening in since the 60's
May 30, 2011 | Uniden BC340CRS Base Scanner
I tried to program the codes in and it isn't working. What am I doing wrong?
Without knowing what you're doing, it's difficult to tell what you're doing wrong, but the first step is to refer to "frequencies" - not "codes". You didn't mention whether or not you have the owner's manual for your scanner, but that's where the best programming instructions can be found. If you don't have the manual, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BCT7om.pdf
You also need to make sure that you have the current frequencies for your area, and remember - your scanner will not work with trunking systems. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
May 26, 2011 | Uniden BCT7 Base Scanner
I need to know how to program this thing I have no Idea what I'm doing it is a uniden bear tracker800 BCT7
The best programming instructions are in the factory manual that you can download and print, at no cost, here:
Bill B.
May 25, 2011 | Uniden BCT7 Base Scanner
I have reset my uniden bc scanner and am trying to re porgram frequencies in i press hold, put in frequency number , press func. and then prgm. and it keeps telling me error. What could be wrong?
First, be sure that the frequency that you're trying to enter is withjin the scanner's tuning range. The ERROR message will appear if you enter an invalid frequency.
Second, follow this sequence to program a known frequency:
- Power the scanner ON.
- Press HOLD.
- Enter the number of the channel you wish to program.
- Press the Func and Pgm keys (channel number will display).
- Enter the frequency, including the decimal point.
- Press E to enter your information into the scanner's memory.
Need the owners manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B.
Dec 08, 2010 | Uniden BC72XLT Handheld Scanner
BCT7 looses programing when power loss occurs whenever the unit is powered on. The unit does not loose programing when the unit is powered off. What gives?
I had the same problem with my BCT7, and after a little research, found this memory backup cap as the problem. It is located next to a transformer near where the 12vdc plugs into the circuit board (the cap is only about a 1/4" tall).
You can get one cheap from the following dealer:
0.047F .047F .047 Farad 5.5V Memory BackUp Capacitors EECFSR5V473
support@westfloridacomponents.com
Nov 25, 2010 | Uniden BCT7 Base Scanner
Please help us program a Uniden BC340CRS scanner.
To program a known frequency into the BC340CRS:
- Press the E/PGM key to enter programming mode
- Enter the number of the channel that you wish to program
- Press HOLD
- Enter the frequency, including the decimal point (e.g., 156.225)
- Press E/PGM to enter the frequency into memory
Press the UP or DOWN arrow to advance to the next channel you wish to program
Press HOLD or SCAN to exit the programming mode.
More detailed programming instructions can be found in the factory operating manual which you can download and print, free of charge, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC340CRS%20%28Manual%29.pdf
Bill B.
Oct 23, 2010 | Uniden BC340CRS Base Scanner
Need manual for bct7 scanner. Don't remember how to program
You can download and print your manual, free of charge, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BCT-7%20%28Manual%29.pdf
Bill B
Aug 09, 2010 | Uniden BCT7 Base Scanner
How do you set up the scanner to scan police and ems channels
First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
Once you've selected your frequencies, power the scanner ON and
1. Press E/PGM to enter the program mode (the scanner turns on the
PGM icon).
2. If the current channel is not the one you want to program, enter the
memory number then press HOLD.
3. Enter the frequency including the decimal point, then press E/PGM.
4. To program the next memory, press  or  and repeat step 3. To
program a different memory, repeat from step 2.
5. To exit program mode, press HOLD or SCAN or change the scanner’s mode.
Notes:
• Any frequency you program replaces the previous memory contents.
• If you enter a frequency you have already stored in a different
memory in Step 3, the scanner beeps and displays the channel
where you have previously stored the frequency. If you want to store
the frequency anyway, press E/PGM a second time in Step 3.
• To clear the contents of a memory, enter “0” in Step 3.
• Channels you program are automatically unlocked (see
“Locking/Unlocking Memories) and have Delay turned on (See
“Setting Channel Delay”).
If you would like to download/print the operating manual for you scanner, visit:
http://uniden.com/pdf/BC340CRSom.pdf
BillB
Jan 11, 2010 | Uniden BC340CRS Base Scanner
I want to unblock my uniden bct7 scanner, Can anybody tell me how
The BCT-7 covers popular frequency bands, skipping things like television signals, non-voice (data) bands, and banned (cellular) bands. It cannot be modified to receive other frequencies. Need the manual for your scanner? You can download/print it here:
Apr 04, 2009 | Uniden BCT7 Base Scanner
Clearing memory
WELL, After a year I alone, without any help from UNIDEN, FIGURED IT OUT.
1. TURN IT OFF, UNPLUG AC JACK IN THE BACK!
2. REMOVE Backup battery cover "underneath" scanner! TAKE ALL 3 BATTERIES OUT.
3. I PUSHED THE POWER BUTTON TO BLEED ANYTHING OFF IN THE CAPACITORS, IF IT HAS ANY INSIDE?
4. PUSH THE"2", "9", AND "HOLD BUTTONS DOWN, THEN PLUG THE A.C. BACK IN ON THE BACK OF THE SCANNER.
5.You WILL notice while you are doing STEP#4 THAT THE DISPLAY SAY'S "CLEAR". ALL FREQUENCIES WILL BE CLEARED IN THE MEMORY!! THEN TURN Scanner OFF reinstall the BATTERIES, TURN BACK ON AND START PROGRAMMING!! THIS WAS FOR A "BC340CRS" SCANNER
Mar 28, 2008 | Uniden BC340CRS Base Scanner
Uniden BCT7 Base Scanner Logo
46 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
