Question about HP OfficeJet 6210 All-In-One InkJet Printer
Paper jam was making a copy and the paper jammed in machine. Can't get paper out. Have made many copies before without problems.
  • lew1930 Jan 15, 2009
    Removed the jam and machine works fine. Thanks, Retsel
    Novelist:
  • 140 Answers
I do not know how much of your machine you can take apart or are comfortable to do, but you definitely need to take the paper trays out and the ink cartridge and get those things out of the way. Next lift the lid so you can see the path the paper feeds through. Do not just pull on the paper with a great deal of force to dislodge it because you may pull on a part that is not intended to move. Following the path will allow you to see where it is stuck. You may need to remove another small cover that is in the way but it will be obvious when and if you need to do that. Be sure your machine is off as you do all this. After you dislodge the paper jam blow out the paper dust that has accumulated in that area as it will cause you alot of problems. More than likely one of your blank pages was slightly bent at the top as it tried to feed through and did not feed evenly. Good luck.
Posted on Jan 14, 2009
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Tip
How to Fix a Paper Jam in a Copy Machine
It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
  1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  2. Step 2 Turn off the copy machine before pulling out the paper.
  3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  4. Step 4 Check for any paper fragments and clean up any torn pieces.
  5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  6. Step 6 Replace the cover and paper tray and turn the machine back on.
  7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
on Jul 14, 2010 | Office Equipment & Supplies
Paper jam in rear
Hi Linda,
1.Open the front cover.
2.Pull out the drum unit and toner cartridge assembly.
3.Open the back cover.
4.Pull the tab toward you to open the rear chute cover.
5.Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull out the paper with the other hand.
6. Close the back cover.
7. Put the drum unit and toner cartridge assembly back into the machine.
8.Close the front cover.
If the error is not cleared, turn the power off on your Brother machine.
If the problem still continues, please contact Brother Customer Service from "Contact Us".
9. Make a test copy. If the machine jams again, try the followings:
10. Make a test copy. If the machine jams again, use new paper from a fresh, unopened ream of paper. If the machine still jams, please contact Brother Customer Service from "Contact Us".
Still having Problem Then follow Us For
Brother Printer Support
Feb 19, 2014 | Brother MFC Office Equipment & Supplies
When we put paper in the printer it goes cricked
Lexmark printer have paper roller problem take printer for once service
Jul 25, 2009 | Lexmark X1270 All-In-One InkJet Printer
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
PAPER JAM
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 19, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Copying
You should be able to open the machine up easily and see the jam. It is a very small unit and no plece for the paper to hide. Does the unit use a film ribbon to print from. If so, remove the ribbon to see the jam.
Aug 09, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
41 people viewed this question
Ben Johnson
