Question about Viking Dishwashers
Viking Dishwasher DFUD042 Pots Pans and Heavy blink, soap door doesn't open
DFUD042 model. Water can be heard in dishwasher but then cycle stops and both the POTS PANS and HEAVY LIGHTS BLINK and the soap door does not open.
markevans
  • 148 Answers
SOURCE: lights on pots and pans blink constantly
try disconnecting power for a bit. try the cord under the sink. if its hard wired (no cord) you can try the breaker.
may reset itself.
otherwise, you have a logic board issue.
consult the manual first for explanation of blinking lights etc.
then call the mfg for further info and if needed, schedule an approved repair person.
good luck
mark
Posted on Dec 28, 2007
  • 93 Answers
SOURCE: The lid to the soap compartment for the second
8 years is a long time for a dishwasher but good going non the less.You will need to open the front panel and check the connections to the dispensor,all switches etc,The water leeking from the door could be a sign that the seal is perrished or simply not sealing aswell as what it should you may also find the machine takes a little to much water for the heavy duty cycle.I think we need to solve the dispensor problem first.Open the front panel and see if all the wires are connected properly and the do a continuity test on the switches,you may find a switch is not functioning properly,if so replace it.The other alternative is get a technition there to check all the problems and see if it is viable to repair as against replacement.Let me know if you need further assistance.If you do please give me make and model and has it got a timer or a pc board in the panel.
Posted on Dec 30, 2009
Testimonial: "Thank you. I appreciate that you commented on each problem and gave considered answers. I guess I show my age when I suggest that 8 years is not old."
  • 7 Answers
SOURCE: When I start the dishwasher it seems like the
Our problem, though for a different make and dishwasher, was solved by this link.http://www.appliancejournal.com/appliance-repair-help/dishwasher-repair-help/ge-dishwasher-repair/ge-dishwasher-motor-repair-problem-100/
Posted on May 05, 2010
MNfisherman
  • 11896 Answers
SOURCE: The detergent door won't open during the cycle and
Either the spray arm is not turning, or the temperature is not getting hot enough which would explain both symptoms. Or the water pressure is too low. Unless the detergent door is faulty and needs to be replaced.
Posted on Oct 19, 2010
  • 3247 Answers
SOURCE: my viking dishwasher won't complete
Have you checked the kitchen sink drain and air gap if one is installed in your kitchen. If using the garbage disposal unit in kitchen then make sure it is clear.
provide model number of dishwasher for further diagnosis.
Posted on Aug 28, 2011
My whirlpool quiet partner II imperial series Dishwasher will only work on light wash mode. Normal wash, heavy wash or pots and pans cycle will not work at all.
This is ordinarily a problem with the touchpad. Can you give me the specific model number of yours (ordinarily on a sticker on the inside edge of the door or on the door opening)?
Mar 06, 2016 | Whirlpool Dishwashers
Why does our dishwasher drain when large items are put through?
if your question is why does the washer drain first when pots and pans mode is selected? the answer is mfg. have realized that most everyone prerinses there pots and pans first , this makes a lot of water drips in bottom of washer this affects the volume of new water it can allow to enter , so they have made it pump out first for a \few minutes when first turned on in that mode ,it should fill after that and wash normally , also this is why its important to use soap dispensers and not just toss the soap in as it may get rinsed away in first few minutes and not get to wash cycle
Feb 16, 2016 | Dishwashers
My viking vdb325ss dishwasher runs for a few minutes and then stops with control pad lights blinking. The "normal cycle" and "pots and pans" lights blink together. I have reset and restarted the dis
Hello Peter!
Your owners manual or a call to Viking should help you decode the blinking panel lights. They are not random and are a desperate cry for help from the machine.
It has been my experience (YMMV) that a common dishwasher problem in older machines is accumulated grunge (the technical term) in the water level sensor. In many cases the sensor lives in a plastic container on the side of the DW and although the designers try hard to avoid contamination, the container eventually loads up and intermittently jams the float.
Before I pulled the unit however, I'd check the bottom of the wash cabinet for contaminants. There may be an screen (under a cover plate) that has clogged.
Your situation sounds a bit different, since my Samsung did not pump out water, it just stopped and flashed a code, but who knows? Go for the low-hanging, common issues first.
All the best.
Nov 23, 2014 | Viking VDB325SS Dishwasher
Kenmore 13789 draining/cleaning issues
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing large plates or pans in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Dec 31, 2012 | Kenmore 13789 / 13782 Dishwasher
Dishwasher doesn't drain completely and then turns itself off. Dishes are not clean.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Sep 12, 2011 | Viking DFUD042 Built-in Dishwasher
My viking dishwasher won't complete it's cycle. The error code that flashes is the heavy pots and pans. We've checked the filter and drains and nothing is clogged. What else could it be?
Aug 28, 2011 | Dishwashers
Hi - my Viking dishwasher has developed a problem where the pump runs continuously, whether the power switch is ON or OFF. After the power is turned ON, the troubleshooting guide indicates that there is...
if you open the kick plate, you'll see the pan below the motor and check for leaks. The leaks will trigger the sensor to pump water out. Once you dry out the pan, the pump motor will stop and you should be able to reset the program.
Oct 15, 2010 | Viking DFUD042 Built-in Dishwasher
Dishwashers Logo
Top Viking Dishwashers Experts
Mike
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
