Question about HP Computers & Internet
Unable to press print button
I am trying to print a PDF file to my HP Deskjet F4280. The file needs to be printed front and back and in grayscale, however my screen is too small to accommodate the menu and my curser can't reach the print icon...
    Genius:
  • HP Master
  • 1,102 Answers
YOU SHOULD BE ABLE TO MOVE THE PAGE OVER SO YOU CAN SEE THE PRINT BUTTON
OR GO INTO CONTROL PANEL DISPLAY AND SETTINGS ADJUST YOUR SETTINGS TO A SMALLER SIZE THEN HIT APPLY
Posted on Jan 13, 2009
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Change ink cartridge
To replace the print cartridges
1.
Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
2. Open the print cartridge door.
The print carriage should move to the far right side of the product. If the print carriage does not move to the right side, turn the product off, and then on.
3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left. If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4. Pull the print cartridge towards you out of its slot.
5. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
6. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place. If you are installing the tri-color print cartridge, slide it into the left slot. If you are installing the black print cartridge, slide it into the right slot.
7. Close the print cartridge door.
8. Close the print cartridge door.
9. Press the Scan button. The product aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Apr 26, 2010 | HP DeskJet F4280 All In One Printer InkJet
I cannot print file in the format I setted in the word
best solution for this is download cute PDF writer. convert the document from Word to pdf and take print out. i prefer this as the best solution because files in PDF occupies less memory space
Dec 01, 2009 | HP DeskJet F4280 All In One Printer InkJet
I have HP deskjet F4288 ,print is not comming.
Try printing a self-test page... to do that please follow below instructions...
Printing a self-test page Follow these steps to print a self-test page from the control panel. Make sure paper is loaded correctly in the product before beginning the procedure.
  1. Press and hold the power button (c01346625.gif ), and then press the cancel button (c01361518.jpg ).
  2. Release both buttons. The self-test page prints.
Thank you.....
Jan 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
My DeskJet F4280 will not print
There are three things that you can try.
1. Exit and restart QuickBooks - try printing again
If this doesn't work
2. Go to your printer setting, double click on the QuickBooks PDF converter to open the printing queue, select any jobs listed and click cancel. If there are no jobs listed or you can't cancel them.
You will need to
3. Delete the PDF converter from the printer list.
Restart QuickBooks and try and reprint.
Hope this helps
3.What you need to do is go to your printer settings and delete the QuickBooks PDF Converter
Jan 27, 2009 | HP DeskJet F4280 All In One Printer InkJet
Ink level problem
Print a test page to determine if the color cartridge is working
  1. Turn on the printer.
  2. If you have an HP Deskjet 710c, 712c, 720c, 722c, or 820c series printer, follow the instructions below:
    1. Turn the printer on.
    2. Press and hold down the Power button while pressing the Resume button four times.
    3. Release the Power button.
  3. If you have any other HP Deskjet printers, click here for instructions on how to print an internal test.
  4. If the printout is black and white, with no color, follow the instructions below:
    1. Open the top cover of the printer and remove the cartridges.
    2. Verify that the correct cartridges are installed in the printer. Click here to see if you have the correct cartridges. If the correct cartridges are installed, make sure that the tape has been removed from the cartridge nozzles.
    3. Insert the cartridges firmly back in their cradles and close the latches.
    4. Close the printer door.
Verify the correct printer is selected as the default printer
  1. In the software application that you are using to print, click File.
  2. Click Print.
  3. In the Print dialog box, verify that the name of the HP printer you are using is listed in the Name box.
  4. If the printer is not listed in the Name box, click the arrowhead to the right of the box.
  5. Click the name of the HP printer.
  6. Click OK.
Check that the printer settings are correct
  1. Close the software application that you are using to print.
  2. Click Start, click Settings, and then click Printers.
  3. Right-click the icon (picture) for the HP printer.
  4. In the menu that displays, use the left mouse button to click Properties.
  5. In the Properties dialog box, click the Details tab. (In Windows 2000, click the Advanced tab.)
  6. Check that the driver listed under Print using the following driver or Printer matches the HP printer you are using. The following setting may be in one of several places, depending on your printer driver and operating system.
  7. In the Details tab, click Setup. Under Printout, select one of the color options. (If other optionshave check marks, click in the check boxes to remove the check marks.) If there is no Setup button, click the Graphics tab, and then click Color. Under Color Control, choose a color option, and click OK. If there is no Graphics tab, click the Advanced tab and look for the text Print in Grayscale. If there is a check mark in the box by Print in Grayscale, click in the box to remove the check mark, and click OK. If you are using Windows 2000, in the Advanced tab, click Printing Defaults. Click the Advanced tab. The box by Print in Grayscale should not be checked.
  8. Click OK.
  9. Close the Printers window.
  10. Open the software application that you were using to print.
  11. Try printing again.
Nov 23, 2008 | HP DeskJet 845c Printer
Won't print
Try the following steps:
Check for and remove any grayscale settings. Use the following steps to check this setting.
  1. In the program, click File and then click Print . The Print dialog box opens.
  2. Select the correct product and then click Properties . The Properties dialog box opens.
  3. Click the Color tab.
  4. Check the Print in Grayscale setting. If necessary, unselect the setting.
  5. Click OK to save the settings.
If this doesnot work:
    1. Open the Printer Toolbox .
    2. Open HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
    Now Click the Estimated Ink Levels tab. This will tell u that the cartridge might be running out of ink even if the graphic shows that there is ink remaining in the cartridge.Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • If this doesnot work:
  • If the Print in grayscale option is not the problem and the print cartridges are not low on ink, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
    1. Load the input tray with unused plain white paper.
    2. Press and hold the Cancel button and then press the Start Copy Color button.
    3. Release both buttons. The self-test page prints.
    This will definitely work for u.
    Thank u.
    May 27, 2008 | HP DeskJet F380 All-In-One Printer
    Computers & Internet Logo
    88 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
