Hi i have an electrolux ewf 1420 but now the light of end flash and nothing els i what can be the problem? pls help
The wasmachine was working okey till al the fuses go out when we fix the fuses the wasmachine would not work more go to end en the light flash and any other button works when i press it
SOURCE: Zanussi jetsystem Turbodry 1200
Hi, Ive moved into a new flat, and I have a zanussi jet stream 1400 turbo dry front loader. Of course, no instructions were left on how to use it. I cant seem to get anything but soaking wet clothes, no spin cycle, and certainly no turbo dry.
Can you tell me where I could download a users manual?
Posted on Feb 10, 2008
  • 3 Answers
SOURCE: Hi i have a electrolux ewf 1074 front loader. it
Press and hold the 'Delay' and 'Extra Rinse' buttons together and it will 'unlock' your control panel (this is a tamper proof feature for the kiddies)
Posted on Jun 11, 2009
  • 4 Answers
SOURCE: Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Posted on Aug 19, 2009
SOURCE: Electrolux EWF 1087 error code E60
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customer error codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Posted on Dec 05, 2009
SOURCE: Electrolux EWF 1087 - Power on, light goes orange, nothing works.
Hold reset and start buttons down, while turning on. Hold down for about 10 seconds.
If you're getting an E90 error code, which means communications error, it means you have a dodgy connection between the main board and the control panel.
Disconnect the power completely, open up the top of the machine and reseat the plugs on both ends on the blue ribbon cable connecting the front panel display to the main board. (The main board is the big white plastic thing with all the wires running into it).
Do the reset steps when turning on again, should be good to go, otherwise it's a bit more serious and you'll need the tech back.
Posted on Jun 30, 2010
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Jun 10, 2016 | Electrolux Washing Machines
Electrolux EWF 1282 start pause button is flashing wont start a load have reset it no error messages came up have also cleaned the drain filter the manual way underneath the machine still nothing any
Hello terry_gwen - Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. I understand that the filter has been cleaned, however, if you noticed a humming noise, it could either be a clogged drainage hose, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Apr 14, 2013 | Electrolux EW1000i Front Load Washer
Electrolux EWF 1074 - How do I turn off the annoying beeps at the end of every wash
I have touchscreen! Doesnt work. Any suggestions? Hate having to get up middle of night to turn off this )%(/₪/#&/₪(" beep!
Feb 29, 2012 | Electrolux EW1000i Front Load Washer
We have a EWF 1087 Electrolux washing machine. Power is getting to the machine as the power light comes on, but ther is nothing on the display screen. Any ideas?? Is it just a fuse??
I had a similar problem with my washing machine too, I was unsure of what the problem was and I was directed to the below website, in the end i paid for a fixed price repair and it was fixed pretty quickly, you may find this helpful too.
http://www.repaircare.co.uk/
Mar 03, 2011 | Washing Machines
Electrolux EWF 1495, spin does not work in quick60 cycle
it,ll will be a circuit board fault, probally the motor inverter board there is 3 pcbs in this model.
May 27, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EWF 1470 Error code E20
could be the element at fault or pressure chamber
Jan 12, 2010 | Washing Machines
The start/pause button is flashing
timer is failed. replace the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Electrolux EW1000i Front Load Washer
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
