Question about Frigidaire FEF326 Electric Kitchen Range
Broiler doesn't work
  • Official Brand Answer
  • 4,342 Answers
Hello wandamacavoy - If the bake element and the top of the unit works, but just not the heating element, then you possibly have a bad broil element or connection. However, if you are experiencing other performance difficulties, then you may have a bad control board that needs to be replaced. Consult a professional for an accurate diagnosis.
Posted on Dec 14, 2012
Kenmore range broiler doesn't work
What is the model number?
Feb 24, 2013 | Kitchen Ranges
The top burner {broiler} workes OK. The bottom burner doesn't lite at all. Both glow plugs [liters ] work fine.
ould be the thermocouple or sensor senseing the ignition. more info would help
Feb 12, 2013 | Kitchen Ranges
Do you have it on the right setting, I did that before.
Dec 11, 2012 | Maytag Stove / Oven / Range Cooktop -...
Broiler doesn't work right
What is the make and model number?
Jan 01, 2012 | Kitchen Ranges
Broiler w/new igniter does not work, gas feed ok
WB13K21 is the ignitor that goes in your stove,i looked up part number RGB 745 and it doesn't come up as a good part number,if the bake ignitor works you can try that up in the broil,they are the same,if it lites then you know the ignitor they put in is no good.here's the sears site so you can see the ignitor yourself.http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Range-Parts/Model-RGB745DEP1CT/1811/0124002/G0907278/00001?blt=06&prst=&shdMod=
Nov 04, 2011 | Hotpoint RGB745 Gas Kitchen Range
I have an Amana ARG7102W P1143347NW gas range that the oven will not light. All other functions work including the broiler and the oven ignitor glows brightly. I don't think it is getting gas to the...
most likely it will be the ignitor,even though it glows it doesn't mean the ignitor is good.it works on amps.a flat ignitor takes 3.2 amps to open the gas valve and a round ignitor takes 2.5 amps to open the valve,the only way to check it is to replace it and i would or if you have an amp meter with a clamp on it you just stick one of the wires going to the ignitor inside the clamp and it will tell you how many amps are coming out of the ignitor.buy a new ignitor and you should be fine.it calls for ignitor part number 31940001 and it's around 50 dollars.
Jun 12, 2011 | Amana Ovens
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Frigidaire FEF326 Electric Kitchen Range Logo
95 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
