Question about RSQ HD-787 HDD Multi-Format Karaoke Player Open Box
Rsq hdd 787 won't power on
Won't power on even though the red power light is on.
Had the RSQ HD 787 for almost a year and now i am having problems. Need help. Can you help me?
Try this:
1. Login as an administrator and open "Device Manager"
2. Click on View and select "Show Hidden Devices"
3. Open "Disk Drives"
4. Delete any device that is grayed out
5. Disconnect your usb cable and reboot your laptop
6. When Windows is fully loaded reconnect your usb cable
Hope that does it for you.
May 16, 2014 | RSQ HD-787 HDD Multi-Format Karaoke Player...
Cd tray will not open or load cd
try to use a safety pin to slide the tray out. u might see a small hole in the tray just slide in ur pin and push it, it might work
May 06, 2014 | RSQ HD-787
I have an rsq 787 320 gb have been adding my songs am at 2252 started adding at 456 it wont add anything more.It say copy cancel disc reader error.I has just had a new hard drive put in it came with 3000...
first find out what parts are failing, the disk?
what disk.? what OS,
do a full scan disk test on disk , if it is corrupted, then, it is.
came with 3000 songs.?
that sounds like a fairy tale to me, nor legal.
if its your backup drive, then where is your alternate BU?
backing up to only 1 device is not going to work,
burn a DVD and burn a flash stick too.
there are recoversoftware that can recover data and skip over the bad. for sure.
Sep 25, 2013 | RSQ HD-787 320GB Hard Drive Multi Format...
Refill water tank light won't go out
Then replace it because they are not repaired.
Jun 30, 2017 | Philips GC 8220 Iron
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Dec 29, 2012 | Nintendo Wii Console
Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Apr 08, 2012 | ASUS Eee PC 1000HE Netbook
Support for rsq HD-787-5 karaoke player
Hi all.
Can anyone tell me . Where I can buy a remote controller for my RSQ-HD-787.
Nov 05, 2010 | Televison & Video
RSQ HD-787 HDD Multi-Format Karaoke Player Open Box Logo
90 people viewed this question
Top RSQ Computers & Internet Experts
David Payne
David Payne
Are you a RSQ Computer and Internet Expert? Answer questions, earn points and help others
