Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
WDS function on this model ? - D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
  • 7,627 Answers
Setting up TP Link TL-WR340GD WDS
Hello maybe the manual could be helpfull:
http://www.tp-link.com/en/products/details/?model=TL-WR340GD#down
You need a pdf reader (ADOBE) to read the content.
Good luck
Nov 20, 2012 | AGPtek TP-Link TL-WR340GD IEEE 802.11g...
Can a DLINK DI-634M WIRELESS ROUTER BE USED AS A REPEATER?
No, sadly it doesn't support WDS (Wireless Distribution System), most of the time I prefer Linksys routers since are easy to configure and WDS capable, if you get two of them I'm sure you can establish a WDS network easily.
May 17, 2011 | D-Link DI-634M Wireless Router (DI634M)
Where can i find the software to download for a EnGenius WLAN 802.11 Router
Software? Here's EnGenius's website. There are upgrades you can download, the program is embedded in the unit. Just do a search for your particular model and you will be rewarded with all kinds of information. http://www.engeniustech.com/index.php/support/manuals-qref
Carl
May 06, 2011 | EnGenius 802.11b/G/N Access Point/Client...
I have two netgear routers and wondered if i can make them work together to extend my wireless internet range e.g. using them as repeaters (rather than having only one turned on depending on the area of...
i dont believe you can do such thing but you could run two routers and log onto each individually. Just like your at home using the laptop and you go to a friends 20 miles away and you take your laptop and it will recognize his wireless allowing access.
Jan 06, 2011 | NetGear DG834G Router
Hi, does belkin wireless router model f5d7234-4-h v5 support wds?
Yes Belkin router Model F5D7234-4-h v5 supports WDS. Please feel to contact us for information.
Jan 05, 2011 | Belkin Computers & Internet
I am configuring a engenius eoc-3610 with wds on a wrv210 cisco wireless router but the internet once setup is very slow.
Every node added to a WDS network cuts the network transmission speed in half. This is just a characteristic of any WDS connection, as WDS is a repeater protocol (it has to retransmit everything it receives).
It's not clear from your description whether you are trying to add the EOC and the Cisco to the same WDS network. If that is the case, it's a wonder you got it to work at all, since WDS implementations are model-specific, and usually require every node to be exactly the same model router.
Sep 24, 2010 | EnGenius 802.11b/g Wireless Access Point
How to connect two speedtouch modems wirelessly ?
  • Hi you need a wireless router to do this,
    PICK A ROUTER - There are tons of wireless routers to choose from. Depending on how big your house or office you might have to purchase multiple routers. The current standard in wireless technology is known as Wireless G. It is rated at a maximum speed of 54Mbps with a radius range of approximately 75'. This is most suitable for small homes or offices. Other types include Wireless A, B, and N and all vary in bandwidth and range. Do some more research and find out what might be suitable for your needs.
  • Step 2PICK A WIRELESS NETWORK CARD - If you set up a wireless network make sure to get wireless networking cards for each desktop, otherwise there'll be no way for you to connect to the internet. Most laptops have wireless networking cards built in, check your laptops manual to make sure.
  • Jul 21, 2010 | Alcatel Speed Touch Home Modem
    WDS Setup
    In a WDS network, all the access points need to be in WDS mode, and one of them needs to be wired directly to a routed internet connection.
    Here is a very good detailed tutorial on how WDS works and how to configure and troubleshoot your own WDS network:
    How To: Setting up WDS Bridging / Repeating
    Jun 03, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
    D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
    I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
    Dec 03, 2008 | Computers & Internet
    What is WDS?
    Wireless Distribution System (WDS) allows you to make a completely wireless infrastructure. Normally, the access points must be connected with a wire (LAN). These access points create cells allowing a wireless connection. The WDS feature allows the access points to be wirelessly connected. This feature is normally used in large, open areas where pulling a wire is restricted or not cost effective and in residential circumstances. If the structure utilizing an access point is too large to cover using one AP, a second AP would be used as a wireless repeater. The WDS has forwarding functionality for extending the range of an AP. By setting up an extended service set (ESS) between access points. Stations can intersect with any AP of this ESS and move between the coverage of both APs while the higher layer network connection remains intact.
    Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
    D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
    151 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
