Question about Dell OptiPlex GX280 PC Desktop
Dell computer wont start up
Hi, my computer was working fine, i plugged something into the USB and restarted my computer, i heard a small bang and the electrical fuse board tripped. I flicked the switch back up on the fuse board, tested the plug which worked and my pc will not power back up! I have changed the fuse on the plug connected to the power box and it still wont work! Have the cpu opened up beside me. Any ideas, im not a computer tech!!! Thanks in advance, Darragh
  • darraghmu595
    darraghmu595 Dec 12, 2012
    Hi Guys thanks for your reply!! But, the computer wont turn on at all, i have nothing connected to the PC, everything is out only the power cable connected! It also tripped the electricity, so question is really, if a computer blows for some reason and trips the electricity fuse board! What would be the likely outcome? i.e, fuse? blown motherboard? thats sort of thing!!!
  • Dell Master
  • 2,878 Answers
Tough one, but inspect the motherboard for a blown capacitor. You could test the power supply with a simple voltmeter. Not to mention simply seeing anything lit with the case open while powered one. gl
Posted on Dec 12, 2012
3 Suggested Answers
techniwiz
  • 275 Answers
SOURCE: dell 4600 usb ports not working
do one thing disconnect all the devices connected to the usb and if possible use a ps2 mouse to do the step i am going to tell you or if u can use the keyboard that would be fine ...
go to device manager and uninstall all that is under universal serial bus ... remove everything that says root hub and than restart the system
Posted on Oct 31, 2008
SOURCE: 4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Posted on May 11, 2009
Hi,my dell optiplex 760 is showing amber light,and 234 is blinking in the back 1 is not lighting atall,can anyone help me please thanks.
Looks like it may be a problem with something plugged into one or more of your USB ports. Unplug them all and restart your computer. If this fixes the problem, plug them back in one at a time to determine the problem device.
Knowledge Base
Jan 30, 2017 | Dell Computers & Internet
Whenever I plug in a usb port device,jumprdrive or whatever, I get a blue screen telling me something it will start dumping memeor and then gives a stop message with a bunch of numbers in brackets. Here is...
run the chkdsk /f on command and prompt
Start, all programs, Accessories, COmmand and prompt on the black screen type chkdsk /f or chkdsk /r restart the computer and it will check for errors and fix them..
if that doesnt work try unintalling the usb driver and then reinstalling it. start, Control panel, system, Device Manager, on device manager , click on usb ports and uninstall it .. or click here http://search.la.dell.com/results.aspx?c=pr&l=en&s=gen&cat=sup&k=usb+driver&rpp=12&p=1&subcat=dyd%2f1000&rf=all&nk=f&sort=K&ira=False&spf=Latitude&ssysid=Latitude+D520&ssysn=D520&~srd=False&ipsys=False&advsrch=False&~ck=anav
this is the dell driver list download any of those 3 drivers and install them . restart the computer and see if the problem stops.
Feb 18, 2010 | Dell Latitude D600 Notebook
I have a dell computer and printer. We relocated
Greetings,
Does the printer show that it is receiving power?
Can the printer run any self tests?
It is possible that the USB cable is the failure point although I would expect that the port got banged around during the move.
The quickest isolation test is to replace the USB cable.
If that still does not work, then a service call may be an option. One other thought, if your PC has multiple USB ports, try the cable in one of them.
Don
Dec 13, 2009 | Dell 1600n All-In-One Laser Printer
Alright, so, I bought a first Gen zune 30 at a pawn shop. A gamble i know. But i turned it on, and it was playing just fine. When i got it home, my comp wont see it. I erased the zune's content via the...
anyone broke the mini-usb plug inside the player?
take it to a service for them to check this.
verify it yourself only if you are familiar in servicing small electronics!!!
Nov 27, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Tried to download new driver for Windows 7 to let my Dell AIO 966 printer work. It says everything is ok but wont print Do i have to uninstall something?
First remove old driver and new from add and remove program and unplug the usb cable and turn it off.Restart computer and redown load driver before plugging in printer and turning it on.Good Luck !!
Nov 11, 2009 | Dell Office Equipment & Supplies
USB electrical shock
Please get the electric rechecked, now if the power supply sounds like it running (Fan Noise ?), any lights on the PC ? no, check the fuse in the mains lead plug leading to the PC,
there is a fuse inside in the power supply but I must advise you to take great care as the capacitors can hold a charge that can cause death for at a couple of days,
Regards
GeWiz
Jun 16, 2009 | Dell (E210882) Motherboard
My computer turns on but the moniter wont
Hi again
Hit F8 on start-up, you will see a sub menu pop up, choose safe mode and hit enter, if it boots into windows safe mode (don't choose system restore) go into device manager and uninstall the graphics drivers and restart the machine, the machine should now boot up and re-install the graphics drivers itself, it may ask to be restarted again.
Any more problems post back
Good luck and thanks for using Fixya!!
Feb 12, 2009 | Dell Dimension 3000 PC Desktop
Computer stalls during startup
How Old is your computer (depending on age, it may not have USB 2.0) that is what you may need to have a external HD now a days
or is it the drivers?
Feb 04, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Grage sale labtop.
Hi with the USB port they often wear and can be tightend by gently prizing up the flat contact strips inside the socket, this requires a fine needle and a steady hand. If this fails just install a PCIMA USB card. the fan could be faulty, if you can use a multimeter then test the contacts and see if you have power to it. Regards mistyman
Oct 02, 2007 | Dell Inspiron 3800 Celeron 500MHZ...
Dell OptiPlex GX280 PC Desktop Logo
Alun Cox
