Logic tv wont turn on
No lights and no sign of turning on i have changed fuses but still nothing
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Someone will need to follow the voltage inside the set, like follow the money.
Posted on Dec 13, 2012
4 Suggested Answers
sethseeling
  • 51 Answers
SOURCE: GREEN LIGHT COMES ON BUT TV WONT LIGHT UP AND WONT TURN OFF
Call the number on your TV manule and tell them you probley have a Loos Fuse in your Tv
Posted on Jan 05, 2010
  • 5 Answers
SOURCE: Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Posted on Jan 25, 2010
AJIN G
  • 6694 Answers
SOURCE: yesterday i was watching tv
hi,
Is there is any standby light in the frond panel of your tv.
If not then the power supply have some problem. First of check the power at the wall outlet socket to which you have connected the tv. Try by connecting to any other power point. Also check the mains chord of the tv is it faulty or not . If these are ok then the power supply is faulty. As it is the most dangorous part I will recommend you to consult some one experience in it. Becuse there are high voltage storage capacitors that will store power even if you disconnect the power. It have the capacity to store the power for two or three days if its is not properly discharged. If you are able to do the same then contact me throug fixya will assist you for the same.
ok
Posted on Jun 11, 2011
My tv wont turn on
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 30, 2015 | Samsung 51" 720p 600Hz Plasma HDTV...
Yesterday i was watching tv i turned it off when i went out but when my husband turned the tv on several hours later it would not turn on it was completley dead is there any logical reason for this i have...
i know these suggestion might sound sometimes stupid and irrational but best to start from the beginning. you use the remote to turn the tv off or turn it off at the wall whilst switched on?
is there a standby light on the tv (usually indicated red)? if this is on its a good sign at least we know the tv is getting power.
is there a standby button on the tv? has this been switched off?
if these fail and you have changed the fuse as you said then it would seem that the tv power unit has burned out and may be time to pull the guarantee out or bring to the local repair shop.
hope this helps
Jun 11, 2011 | Televison & Video
Turns on and off by itself
If this happens on all inputs and you have disconnected the power and reconnected it and that didnt fix it.
Sounds like a logic board issue problem is LG only warrenties tvs for 1 - 2 yrs.
Jun 16, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv wont turn on, changed .5 amp fuse but nothing, its a 47 inch tevion lcd tv
hello have you check the fuse inside the tv glass type it will be in the power supply
regards
shaun
Jun 14, 2010 | Televison & Video
Jan 05, 2010 | Apex Digital LD1919 19 in. LCD TV
TV won't turn on
Shorted problem. Maybe in primary or secondary power supply. Need a repairman. Busted regulator, or shorted diode.
Apr 17, 2008 | Samsung SlimFit TX-T2782 HDTV
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
LCD TV WONT POWER ON
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Nov 28, 2007 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
