Question about Philips Magnavox Learning Universal Remote
Worked for yrs, then i may have touced it wrong now dont work
Tried all the online ideas,and nothing. found the codes for my samsung tv but no sucess. am i doing it wrong? i dont have original paperwork anymore.
  • Anonymous Jan 03, 2008
    i dont know the component number code
  • Krystal Wynn Feb 07, 2009
    NEED CODES FOR REMOTE TO PROGRAM MY TV
I am needing codes for my remote control to my tv.
Posted on Jan 04, 2008
  • 30 Answers
Try the Main support number 1-888-PHILIPS
Posted on Jul 17, 2007
SOURCE:
I have URC2490 Total remote. The codes for my Logik TV don't work and the search for code has found nothing. Why is this so secret? Anybody have any ideas please?
Your Logik TV may require a code that the remote does not have stored in its code library. You may have to try a different remote but even with that there is no guarantee of success.
Dec 06, 2014 | Televison & Video
Got a PS3 hooked upto a Samsung 40" LCD TV via
I would suggest trying a different TV, and maybe see if you still have any Component or Standard Definition Composite cables to connect the PS3 to the TV and see if it works that way. I would assume you did this when you said you reset the resolution on your PS3, but turn it off, then hold in the power button until it beeps twice in a row. (Just in case) Make sure everything is plugged in twice and your TV is on the right input. If none of that works, there may be something wrong with the graphics adapters on your PS3 in which case you will need to contact Sony about fixing it.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
I followed the instructions (Brookstone giant remote and Samsung TV) above for manual programming and it worked.... that is it went on. But the volume control doesn't respond and I can't change the...
sometimes there is more than one code that will work for your tv even though its not the right one. Try all the samsung codes even if you found one that worked, try the rest.
Samsung - 043, 048, 054, 057, 062, 073, 074, 075, 078, 080, 089, 092, 097, 104, 112, 117, 118, 125, 131, 139.
Feb 09, 2011 | Brookstone 538744 Remote Control
I am trying to program my samsung universal remote ak59-00104k for use with a visio tv.... I've used random codes and finally found a tv code that works everything except the tv source. How do I get that...
Go online and type in "Samsung Ak59-00104k" and it should pull up a list of websites that deal with that product including several that have lists of all of the codes. Most of these are free.
Dec 28, 2010 | Samsung Ak59-00104k Remote Control
Code for Sky+ remote to work with Toshiba TV AV635DB
Hi there. I have just bought the same television today and I have just found that the remote code 0156 does actually work. The mistake i initially made was not pressing the TV BUTTON after I had held in the SELECT and RED Buttons together, making the light blink twice. So here's what I did:
1. Press the TV button
2. Hold in the Select and Red Button until the red light flashes twice
3. Press the TV button again
4. Enter the code 0156 (The Red light will blink Twice again)
5. Test the controller - Try to change the volume
6. If it works, press SELECT one last time to save the settings.
Hope this helps.
apnit
Jan 04, 2010 | Televison & Video
Samsung Pixon touch screen frozen
The issue of touc screen freezing in he M880 is mostly due to fault in the contact. The screen contact is just below the volumen control buttons on the right. I inserted a fingre nain where the volume control is and pulled up the screena wee bit. near the volume up botton, I then inserted the tip of a tooth pick. It worked and the touch sensitivity is just as new :)
Sep 09, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
I have a 27" color flat screen tv by Samsung which I bought from Best Buy in Lakeland, FL 4 yrs ago never had a problem til now. I had a power outage in my home but the tv wasn't on nor was the...
Try to use your directv box with a different A/V connection to the TV and see what happens?
EX. If you have a basic directv box using coaxial cable connection,try to use RCA(yellow,red/white) cable to a RCA input behind the tv.
solutiondoct
Nov 22, 2008 | Televison & Video
Wrong disc on screen
If you DVD player is damaged, and u have external AUDIO\VIDEO inputs.Buy a $59.00 scan DVD player & save yourself a $100 repair bill.
The DVD heads coud be internittan { sometimes it works & sometimes i don't } U could have issues with the country codes that tell your DVD where the DVD CD was made at or where is was recorded.
Mar 26, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
Philips Magnavox Learning Universal Remote Logo
146 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
