Question about HP Photosmart Premium C309A All-In-One Printer
HP Office jet 7500A error code 0X601011 beb
+new printer will not get past this code
  • 25 Answers
SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
Preventing paper jams
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Posted on Jul 08, 2008
futureloginn
  • 734 Answers
SOURCE: Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Posted on Nov 27, 2008
moderator
  • 6 Answers
SOURCE: hp 6500 office jet refill
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
www.catherinecollege.net
Posted on Aug 12, 2009
SOURCE: HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Posted on Dec 29, 2009
  • 79 Answers
SOURCE: HP 4200 Laser Jet Printer Error Code 82.0180
The error message "83.0180" shows that an EIO error has occured.
Perform the following workaround and see whether the issue still persist.
1. Ensure that the printer is connected directly to the wall outlet.
2. Turn off the printer and then power on and see whether the issue persist.
3. Reseat the Jetdirect card and see whether the issue still persist.
4. Reseat the jetdirect card on a different slot and see whether the issue still persist.
5. Remove all the accessories from the printer and then power on the printer. See whether the issue still persist. If the issue does not persist, add on the accessories onee by one.
6. Power on the printer and check whether the issue persist, each time an accessories are added.
7. Swap the Jet direct card with a known good jet direct card and see whether the issue still persist.
8. Perform a cold reset and see whether the issue still persist.
To do a Cold Reset:
1. Remove all cables.
2. Press & hold the Test button while applying power & continue to hold it for 10 seconds, then release it for 10 seconds, then unplug it again.
3. Connect all cables & power it back up.
4. Wait 2 minutes for discovery & DHCP. If desired, change the DHCP & address settings.
Posted on May 07, 2010
Empty carriage stuck in my HP 7500A printer
Hello,Lester Makang
Your carriage got stuck in service station,is there any noise coming from the right side of printer then there will be broken gear.
Power on your printer,after you got carriage jam error open cartridge access door and wait 5 second when you see that gears trying to move,use your hand to pull your carriage to left side.Don't use much force.If your carriage got free then install your print head and cartridges.If this will happen again then take it to service center they will change the service station or broken gear but the cost goes much high.
Nov 06, 2012 | HP Officejet 7500a E910 Multifunction...
Hp officejet 7500a error B848DB90 solution
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 25, 2012 | Office Equipment & Supplies
HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
G 55 Office Jet error code
Are all the lights flashing....probably a main board.
Inkworks
866-381-0541
Oct 20, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
HP Photosmart Premium C309A  All-In-One Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
