Question about Samsung LN32C540F2D 32 LCD TV
Tv will not turn on light turn on an it falshing
Put in new power board an still not working
Model KDL32BX300. Why won't it turn on?
PLEASE CHANGE THE INVERTER BOARD BECAUSE YOUR 24 VOLTS ARE SHOTED
Dec 20, 2015 | Sony Televison & Video
I have LC-42D65U and unable to turn on the TV after experiencing power outage. Seems like its power button works and briefly hear the sounds, but cannot see the screen. After power outage, I have reset the...
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
Aug 11, 2011 | Sharp LC42D65U 42 in. LCD HDTV
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
TH-42PX70B wont switch on - standby light falshes green but TV won't switch on
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
Dec 02, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Hello. I got a Lg tv which i brought 3 years ago. After putting it on standby usually the red light falshes 3 times until it turns blue and comes on. since last week the red botton just flashes...
First disconnect all power to the TV for about 30 minutes this gives the filter caps time to discharge as this resets the logic section upon power-up. After 30 min try powering back up if you still have the same problem then there's a problem with the power supply board. You may have some caps with high ESR levels which can cause this kind of fault. But it could other components on the power board causing a similar fault like switching transformers that have shorted, or opened either which can cause EDDY Currents which will cause feedback in opto-couplers and shut the TV down. Let me know what results you get after the 30 minute power-down.
Oct 18, 2010 | LG 37LG30 37 in. LCD HDTV
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
SVA 42 inch plasma (HD4208TIII-PDP)sometimes turns on
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, justpress tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Mar 26, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Mikomi flashing blue light tv will not work
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Mar 23, 2009 | RCA Mikomi 5290925 15 in. LCD TV
Samsung LN32C540F2D 32 LCD TV Logo
Jerry Greenberg
Jerry Greenberg
