Question about HP Designjet 4500mfp All-In-One InkJet Printer
86:01 error message on hp designjet 4500mfp after belt replacement
PRINTER WAS DISPLAYING 86:01 ERROR MESSAGE. I NOTICED THE BELT WAS WORN AND TORN. I REPLACED THE BELT AND CLEANED THE INSIDE OF THE PRINTER AND STILL BEING PROMPTED WITH THE ERROR MESSAGE.
SOURCE: HP J8750 Cartridge error
I had this "Cartridge error" problem on my HP J5780 printer. Replaced the cartridge, but still got the same error. Then removed the cartridge and used a cotton swab with a little denatured alcohol, and gently and carefully cleaned the contacts in the printer. Followed this with a dry swab to be sure no alcohol left. Replaced the original cartridge, and have been using it for a week now with no more error message.
Casey K.
Posted on Nov 12, 2008
  • 8 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800 Printer
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
Posted on Dec 15, 2008
SOURCE: HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Posted on Dec 05, 2009
SOURCE: hp designjet 9000s system error 1290
sistem error 1290
Posted on Feb 20, 2010
SOURCE: HP 800 designjet plotter Error Message 21:10
need to replace service unit
Posted on Mar 22, 2010
How to hook up fax on a HP 4500 all in one
No fax facility for this models...HP designjet 4500 or deskjet F4500
Jan 04, 2012 | HP Designjet 4500mfp All-In-One InkJet...
I have a 3500Cp Hewlett Packard and the band is wearing down that moves the printheads. Now it is giving me a 020011 001000da error
If the belt is worn out and you get this message then the belt is the most likely problem. You may need to clean the encoder strip but I would suspect the belt. Do not cut yourself if you clean the encoder strip. Unless you have replaced a belt before I suggest getting a tech that knows how.
Jul 14, 2011 | HP DesignJet 3500cp InkJet Printer
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
I have problem with my 5500 hp: check printhead path 2
The most common cause of the Check Print Head Path Error 2 is a worn out carriage belt. Open the top cover and locate the carriage belt. It is the long thin belt that extends the full length of the plotter. Use a light and look under the belt for debris that looks like pencil erasure crumbs. If the crumbs are there, the belt is disintegrating and needs to be replaced. See: http://www.lpscomputer.com/c-732-designjet-5000-5500-belt.aspx
Dec 01, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
Error message reads "switch power off check printhead path type 2", any suggestions. I have cleaned along the track but problem persists on power up. Head alignment begins and after a short while the error...
there is an issue with your carriage assembly. it cannot move freely across the carriage rail assembly. the belt may be worn, lubricate the rail assembly or both.
Nov 16, 2009 | HP DesignJet 1050c InkJet Printer
DESIGNJET 755cm ERROR MESSAGE: TURN OFF PLOTTER CHECK PAPER PATH. THERE IS NO OBVIOUS BLOCKAGE TO PAPER PATH
If there is no obvious obstruction in the print head path, the most likely problem is a worn carriage belt. Open the front lid and check for rubber crumbs under the carriage belt. If there are crumbs, the belt is disintegrating and needs to be replaced.
The service manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm and the parts are available at: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Oct 10, 2009 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
When I turn on my HP designjet T 1100 I get error message 08:11
turn off printer, disconect hdd from pcb, turn on then printer beeps, turn off mount hdd back, turno whait ;).
Mar 19, 2009 | HP Designjet T1100ps Printer
HP Designjet 4500mfp All-In-One InkJet Printer Logo
88 people viewed this question
Seeker5211
Seeker5211
