Question about Itomic IMID10MT 10" Android 2.3 Gingerbread Tablet w/ 1.14GHz ARM11 Processor, 512MB RAM, 4GB Internal Storage, 1024 x 600 Resolution, 16:9 Aspect Ratio, Capacitive Touchscreen, Integrated Webcam, Microphone, Speakers, Gyroscope Sensor, Headphone Jack & HDM
Update operating system to the latest 2.3 os - Itomic IMID10MT 10" Android 2.3 Gingerbread Tablet w/ 1.14GHz ARM11 Processor, 512MB RAM, 4GB Internal Storage, 1024 x 600 Resolution, 16:9 Aspect Ratio, Capacitive Touchscreen, Integrated Webcam, Microphone, Speakers, Gyroscope Sensor, Headphone Jack & HDM
Cant up date m/s security essentials or delete
Step1 Ensure that the date and time are set correctly on your PC
Open Microsoft Security Essentials.
If the error message that you received contains the code 0x80072f8f, the problem is most likely caused by an incorrect date or time setting on your PC.
To reset your PC's date or time setting, follow the steps in Fix broken desktop shortcuts and common system maintenance tasks.
Step 2
There are other things that you can do however the most easy way is to install updates manually
Manually install the virus and spyware definition updates
If you're running a 32-bit Windows operating system, download the latest updates manually at http://go.microsoft.com/fwlink/?LinkID=87342
If you're running a 64-bit Windows operating system, download the latest updates manually at
http://go.microsoft.com/fwlink/LinkID=87341.
Click Run. The latest updates are manually installed on your PC. http://go.microsoft.com/fwlink/?LinkID=87342 http://go.microsoft.com/fwlink/LinkID=87341
Apr 08, 2016 | Microsoft Windows 7 Ultimate. Windows 7...
Skype update won't download on my Mac
If you cannot get Skype to update, I would delete the application entirely and then visit Skype.com and install the latest version.
Hope that helps!
Oct 10, 2012 | Apple Mac OS X Snow Leopard (10.6.8)
What do I use to update android os
Not a whole lot of updates come out for Android. Most of the updates that are released are pushed/provided from your service provider.
Updating from the Android OS.
1. Turn on your phone.
2. Tap the menu key. (4 small squares).
3. Tap settings.
4. Tap About phone.
5. Tap System Updates.
6. The phone should check for available updates and install them if any are available.
I am sorry I can't provide you with the latest update version since I do not know what the model of your phone is.
Justin
May 02, 2011 | Computers & Internet
I have toshiba laptop satellite l650-15g core i5 is working to slow like Pentium 2 every think is opening to late please help me fast
use these steps:
1- reinstall your operating system (OS).
2- after the OS installed , download and install a powerful anti virus(with latest updates) (like NOD32 ANTI Virus or Kaspersky etc)
3- start a full scan (in anti virus options).
4- reinstall your OS again and enjoy fast speed.
NOTE:always remember to use an updated anti virus on your Laptop.
and if your laptop worked slow again use this way:
1- start "RUN" from start menu.(if you are using windows 7 go to accessories)
2- enter "msconfig".
3- go to startup tab.
4- disable some installed software (like yahoo messenger or ID Manager etc) in start up but be careful not to disable windows applications.
Jan 12, 2011 | Toshiba Computers & Internet
I recently purchased a new computer with windows 7, can you tell me if there is a software update for the personal legal forms?
No need Just Install the Operating System and Activate your Operating System Online or affine then you can update your OS with Latest Updates and you can enjoy the Genuine Advantage
You can check you Operating System is Genuine or not using this site http://www.microsoft.com/genuine/
Aug 11, 2010 | Proventure Personal Legal Forms (5913) for...
Windows cannot configure this wireless network
What OS are you running? XP? Most wireless networks are now using the WPA protocol and computers with XP that are not updated at least to SP2 will not connect to these networks even though you can see them available. I would go ahead and updated to the latest SP3 (Service Pack 3). I cant really be more helpful without knowing the OS (operating system).
Mar 02, 2010 | Computers & Internet
Need to know where I can get driver download.
Possible causes:
1)The Operating System on the computer might not support the Plug & Play feature or need latest system updates.
2)The USB port or PCI slot on the computer might be faulty.
3)Extension cable (if being used) that connects the USB adapter and the computer might be faulty.
4)There is no driver support for the Operating system.
Symptoms:
1)LED will not light up on the adapter.
2)Found New Hardware Wizard does not come up.
Resolutions:
1) Make sure you meet the minimum system requirements for the adapter and have the latest updates on the computer.
2)Use the latest driver for the adapter. Latest drivers link is mentioned below.
3)Try a different USB port or PCI slot on the computer.
4)Try another device and check if it gets detected.
5)Try to connect the adapter directly to the computer without using an extension cable.
6)Try restarting the computer or try adapter on a different computer.
Open the below link and try to download the latest version of the driver http://kb.netgear.com/app/answers/detail/a_id/747
May 18, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Latest bios update
if your comp has recently slowed down it is advisable to get a recomended virus and spyware/adware cleaner and do a scan with the latest updates and definitions installed.and like bootz84 said clean the heardware and give your os a spring clean.
in extreme case a factory default or a new install operating system can also be influential.
May 08, 2009 | Intel D101GGC Motherboard
My Acer Orbit cam is not functionly well
Try to update it with the latest updates using windows update feature ...
Nov 16, 2008 | Acer Aspire 5100 Notebook
How to format w900?
Brother, I am afraid that there is Only one Solution to this problem, Flash & Reinstall the Latest Operating System as u cant format the W900 To Flash & upgrade to the latest OS please follow either of the option given below:- 1)ONLINE FLASHING Buy a DCU-60 CABLE & Visit.. http://www.wotanserver.com/en/supported-phones/sonyericsson-w900-debranding Buy 1 WotanServer Credit (costs 7 EUR, Paypal Accepted), after u buy a credit you'll be able to flash your phone by creating an account. Once the account is created just log in, connect your phone to the PC via DCU-60 CABLE & Click on UPDATE SOFTWARE. where you can choose the latest firmware for your phone (R5BC004 CID49) Within few minutes your phone will be Flashed + Updated to the Latest Operating System :) OR 2)SERVICE CENTRE Visit the nearest Sony Ericsson Service Centre
Aug 03, 2007 | Sony Ericsson W900i Cellular Phone
Itomic IMID10MT 10" Android 2.3 Gingerbread Tablet w/ 1.14GHz ARM11 Processor, 512MB RAM, 4GB Internal Storage, 1024 x 600 Resolution, 16:9 Aspect Ratio, Capacitive Touchscreen, Integrated Webcam, Microphone, Speakers, Gyroscope Sensor, Headphone Jack & HDM Logo
26 people viewed this question
Top Itomic Computers & Internet Experts
David Payne
David Payne
Are you an Itomic Computer and Internet Expert? Answer questions, earn points and help others
