Question about IBM NetVista PC Desktop
Thanks for your help
Im the guy with the sound jumper problem. thank you for your help thus far. i have the mobo pulled out now. is this problem something i should wait for a answer or should i put it back together without sound. i was shocked how quickly you answered my question earlier and im not sure if the info you need to solve this problem is easy to find or not.
should i keep waiting or search for another solution?
  • 2 more comments
  • jason K
    jason K Jan 13, 2009
    oh its quite alright im very happy to have tech support. i appreciate any help anyone can offer. do you have a link to the new post so i can watch it? or can you keep me informed? should i rattle the mobo back into the case? are the numbers i gave you relivant?
  • jason K
    so if i call lenovo i should ask for what case i have? and from this info i can figure out how to set the jumpers?
    just to be clear i had this working then took out the jumpers and cant remeber where they go back in and now its not working.
    what are "the front pannel pins"?
  • jason K
    so there is no concrete way to get a diagram for these to work. even with the case info?
  • jason K
    jason K Jan 14, 2009
    i wish i could but i have tried 2 different sound cards and to no avail
    Master:
  • 413 Answers
I am trying to download the pdf file now. I had to leave for lunch but i am back at it now. And getting somewhere i think i found the pdf file i needed
Posted on Jan 13, 2009
  • 5 more comments
  • Dan rogers
    Dan rogers Jan 13, 2009
    Well i finally got the pdf files downloaded but nothing shows about the front sound panel. So i have posted this problem in the "experts lounge" I hope someone in there can help us out. I'm sorry for the time this is taking and I am trying to do everything i can.
  • Dan rogers
    http://www.fixya.com/ExpertsLoungeThread...
    This is the link to the forum. I am still looking though so don't give up all hope yet
  • Dan rogers
    I have found the solution!!!!! And the reason this was so hard to find... The reason we cannot find this anywhere is because this motherboard was made for a specific line of cases. These cases have a plug that plugs into the front panel pins. That is why there is no diagram on how to set these. To find out what case you need you will have to contact lenovo (sorry) as i cannot find this information.
    Please don't forget to rate this solution accordingly!
  • Dan rogers
    Sorry i just saw the last part the only numbers you need to look up this board are = FRU-49P4384 This is the model number of your motherboard
  • Dan rogers
    The front panel pins control the lights switches and sometimes audio. You can get these to work again without the plug but you will just have to play around with the pins until you find the ones that work
  • Dan rogers
    Maybe if you had the case info. Actually never thought of that.
  • Dan rogers
    Dan rogers Jan 14, 2009
    another way around this sound jumper problem would be just to install a sound card. They are pretty cheap and shouldn't be too bad to install the drivers.
I have a Soya SY-7VCA mobo that hasn't been used for about 6 years. Upon bootup, I received a CMOS checksum error message, but was still able to load a copy of Windows 98SE that I had on floppy. After...
Probably your BIOS battery, replace that and setup you BIOS again and it should be fine. BIOS batteries look like little round watch batteries.
Any more questions just let me know.
Thanks
John
Feb 14, 2011 | Soyo SY-7VCA Motherboard
I HAVE A TOSHIBA MODEL:L505-S5990 I HAVE A PASSWORD BIOS HELP TO UNLOCK MY LAPTOP THANKS ADVANCE SAY ME WHAT CAN I DO
locate the jumpers for reseting the BIOS with hardware... beware all settings on CMOS would be restored to default factory settings and password will be erased. Jumpers would be on the mobo near the proc/ near the memory modules/ near the edge etc...learn to use the jumpers from manuals for ur model of laptop...cos each model varies in the location and use of jumpers
Sep 05, 2010 | Toshiba Satellite Pro L300 Notebook
Dell Dimension 3000, splashed liquid from canned air, mobo fried?
The spray on the MB should not be a problem - unless it was plugged in when you did it. Yes, you should be able to put in a new Dell motherboard. As long as the processor is of the same class, the Dell license should work fine. However, you may need to download new drivers for the machine to run.
If you really want to check the power supply, I would suggest you buy a tester. They are fairly cheap: $10-50. You want to be sure that your board is getting the right power at the right places. 12 V to the fan is fine. However, 3.3 v or 1.5 v?
It sounds like you have done a fairly good test of the motherboard. I've definitely seen bad Dell motherboards with the light on with/without a bad power supply.
If you have another case (an ATX), I would buy an Asus or other motherboard and put your equipment in it. The cost of a Dell motherboard is excessive. Of course, you will have license problems with XP.
May 22, 2010 | Dell (E210882) Motherboard
I cannot get past Bios screen, no mouse,keyboard,safemode,F keys nothing, Can this be fixed please or is it a new MOBO. Thank you. Eddie
sounds like a hardware compatilibilty issue. Reset cmos, double check all connections and jumpers and try a new memory
Mar 27, 2009 | Computers & Internet
No audio
ok. post your computer model number example=t2080, producer eg=emachine, hp, dell........, I cam help you when you post all this to the forum and to my email to notify me. innocent.asia@yahoo.com
Jun 13, 2008 | Computers & Internet
SL-KT400-A4C - SOLTEK MOBO
yes check the switch settings on the motherboard , select the right settings for your processor.
Apr 08, 2008 | Computers & Internet
Will not boot up at start
this sounds like a mobo issue .... if the machine has been in service for a while or is in a dusty environment a good internal vacume / brushing to remove dust buildup from the mobo might help.... also disconnect and reconnect the main powwer connectors from the mobo... the power button on the case is simply a contact which jumpers the two pins on the mobo... the actual power switching takes place withing the power circuits built into the mobo... you may also try a mobo driver update if it is available
Mar 29, 2008 | E-Machines eMachines Desktop PC
GA-8VM800M-775 WILL NOT START UP
Pete, did you try the onboard video, also?
When you tried the add-on video card, did you change the setting in the BIOS?
Jan 15, 2008 | Intel Motherboard
No Picture
Hi! Guy,
This sounds like a defective large signal board. This set should be serviced by a qualified
service tech.
Toprol
Jul 13, 2007 | Philips 55PW9363 55" Rear Projection...
IBM NetVista PC Desktop Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
