Question about D-Link AirPlus DI-524 Wireless Router
Automaticly restarting, shooting down
I am using D-link router over one year. In last couple weeks router started shooting down itself. From beginning that happens once or twice a week this time its twice a day. Sometime it's just rebooting. Another time it stays off. It is not getting hot. Otherwise it's working perfectly.
    President:
  • 2,961 Answers
First try a reset in your router settings, by typing 192.168.0.1 in your web browser, and you also may have to try a firmware update, but you need to find the version of your router underneath, so refer to this page and see if you have the current firmware:- http://support.dlink.com/products/revision.asp Please be aware that any firmware upgrades need to be done with the rj45 cable and not wirelessly Otherwise, if it's rebooting it could be the W32.Blaster Worm, many other variations of this worm have been found. Some of them are W32/Lovsan.worm and W32/Nachi.worm. These worms create a lot of ICMP traffic which may overload the router to eventually prevent it from communicating. Whether it´s the CPU or another component of the router that causes the failure, the problem can only be solved through the removal of this virus. There´s a tool provided by McAfee called Stinger. This tool will detect and remove the viruses that cause these problems. Please take a minute to read about this tools and it´s usage. You will need to run this tool on every single computer. the tool can be found here:- http://vil.nai.com/vil/stinger/
Posted on Jun 12, 2007
My galaxy s2 turns itself off all the time. Have to take battery out/put back in to restart. Help.
This problem can be on your battery to check that you can move your phone in you hand so hard if it turn itself off so you must change another battery, Else you have a problem in the charging circuit.
Dec 03, 2012 | Samsung Galaxy S II
The engine doesn't start. I didn't use it for several years. It started and ran well for about an hour; when I shut it off, I could not restart. I have tried the obvious...new plug, putting started
You need to give the carburetor a good cleaning, as well as the air filter. Chances are the carb. will need a new carb. kit since it has been years since you last used it. If you need tips on how to clean the carb., just let me know.
Jim
May 30, 2009 | Mtd Garden
I cannot pick up a internet connection
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
Feb 28, 2009 | HP Computers & Internet
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
No internet connection through di-624 from laptop
if you give the automatic ip address obtian throught dhcp in that you give proxery server if there then remove it . and go to the router page and go to dhcp in that you enable and give the dns there and ip address you isp . then you get it after then you not get it then disable the proxery server. in laptop give both automatic.
Feb 04, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
PC won't boot
When you can get it to start, go directly into the bios. Once there find hardware monitor. (if your bios supports that). If so, here you can monitor cpu & motherboard tempture. Just let it sit. If its a heat issue you will be able to see it in the bios. Also lets see if the pc restarts by itself. If no restart takes place I would guess this is a software issue. Possible virus/worm. Pull the system memory & reseat. Reinstall windows.
Jan 17, 2008 | Soyo P4I865PE+ DRAGON2 (SFP4I865PE)...
Restart
Change out the power supply. Dell had this problem with one of there desktop product lines.
Oct 07, 2007 | Acer Altos G700 Server
D-Link AirPlus DI-524 Wireless Router Logo
124 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
