Question about MicroNet New - Fantom Databank Fdb16u2 16 Gb Usb 2.0 Flash Drive - Kd2986
How to remove the write protect on a fantom databank usb flash drive
I've tried the safe mode with command prompt but still give me same write protect problem
  • david williams Dec 14, 2012
    I've also tried regedit...same results
  • 508 Answers
Why would you try regedit on this? Depending on what files you are trying to delete you should be able to just right click on them and bring up the properties, once you do that you can change them or if you really want them gone just format the drive. Don't use safe mode for this just boot up the computer install the drive once the operating system sees it you should be able to change the properties using the above method.
Posted on Mar 30, 2014
All of a sudden is Write Protected
Is there a lock icon on the drive anywhere? If so, there is some kind of switch there that you need to move to unlocked.
Try right-clicking on the drive, select Properties and then look for a checkbox that locks the drive.
Try editing the registry:
http://ccm.net/faq/4214-remove-write-protection-from-a-usb-key-via-the-registry
Sep 01, 2015 | Fantom Drives Databank 64gb Usb 2.0 Flash...
Tip
How to Bypass Windows XP Password in Safe Mode?
As a special diagnostic operating mode of Windows, safe mode which starts Windows with a limited set of files and drivers helps you to diagnose and troubleshoot various computer problems. Whenever your computer crashes or a spyware or virus affects your PC, you can enter safe mode to fix these problems. So when you want to <a href="http://www.anypasswordrecovery.com/bypass-windows-xp-password.html" style="font-weight: bold;">bypass Windows XP password</a>.<br /><br />There are 3 safe mode options, here only shows you detailed instructions on <a href="http://www.anypasswordrecovery.com/bypass-windows-xp-password.html" style="font-weight: bold;">how to bypass windows XP password</a> by safe mode with command prompt, which will starts Windows in safe mode with a command prompt window instead of the usual Windows interface. Before proceeding the following steps, please make sure that you never set a password for the built-in administrator account on your Windows XP machine or you can remember password of a Windows account with administrative privileges.<br /><br />Step 1. Turn on your computer.<br /><br />Step 2. Repeatedly tap F8 key as the computer is booting. It will bring up the "Windows Advanced Options Menu" as shown below.<br /><br /><img src="yaoch.png" /><br /><br />Step 3. Use your arrow keys to select "Safe Mode with Command Prompt" and press Enter.<br /><br />Step 4. Windows will load files until you see a logon screen similar screen with all your account user names displayed. Enter password for your administrator account to get in safe mode.<br /><br />Step 5. You'll see Windows command prompt after entering safe mode.<br /><br />Step 6. Enter "net user" on the command prompt, and press Enter. It will list all the user names of your Windows accounts. Here we assume that there is a user name of "Jack" in the list and you want to bypass the "Jack" account password.<br /><br />Step 7. Enter "net user Jack 123456" on command prompt and press Enter. This command line means that you want to reset the lost "Jack" account password to "123456". When it takes effect, you'll be able to logon the Jack account with the new password of "123456".<br /><br /><img src="yaoch_0.png" /><br /><br />Step 8. Now all the operations compete and you can exit safe mode by restarting computer.<br /><br />Please note this method will not work for you if you cannot enter safe mode with an administrator account. Under this circumstance, what should you do next? Well, don't feel impressed. Windows password recovery solutions aren't limited to this. <a href="http://www.anypasswordrecovery.com/" style="font-weight: bold;">Rekeysoft Windows Password Recovery</a> is another good choice. It only takes you 4 steps to bypass Windows XP password in less than 5 minutes.<br /><br />Step 1. Download and install Windows Password Recovery.<br /><br />Step 2. Burn a bootable Windows password reset CD/DVD/USB flash drive.<br /><br />Step 3. Insert the CD/DVD/USB flash drive in the locked computer and set BIOS of the computer to boot from CD/DVD/USB flash drive.<br /><br />Step 4: <a href="http://www.anypasswordrecovery.com/reset-windows-xp-password.html" style="font-weight: bold;">Reset Windows XP password</a> under Win PE with a few clicks.<br /><br />Of course, if you had created a password reset disk after creating a Windows password, you can easily use this disk to change the lost login password to a new one with ease. It will save you from a lot of troubles when forgot login password to your Windows XP computer.
on Apr 19, 2011 | Computers & Internet
Tip
How to Bypass Windows Password With Ease?
Nowadays, it comes a common sense to add a BIOS or Windows password for laptop protected. Thus, a feasible advice is to create a Windows password disk in case that you forgot Windows password. But without Windows password reset disk, what should we do in order to bypass Windows password?
It's time to learn how to bypass Windows password with the following two tips and tricks.
Method 1: Bypass Windows password by Safe Mode with Command Prompt
According to Wiki, Safe Mode is a diagnostic mode of a computer Operating System (OS), a special way for Windows to load when a system-critical problem interfering with normal operation of Windows. If you are not able to boot your computer in normal mode or supposed your notebook is infected with Trojans or malware, you are able to get rid of them with Safe Mode. Furthermore, it is easier and safer to bypass Windows password in Safe Mode when you lost or forgot Windows password.
Take Windows 7 for example: there are 3 different types of safe mode: Safe Mode, Safe Mode with Networking, and Safe Mode with Command Prompt. Below is a guide on how to bypass Windows 7 password with Safe Mode with Command Prompt, which allows you to bypass Windows password with command line. Detailed steps are as follow:
Step 1. Boot or reboot your Windows 7 computer.
Step 2. Press F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Step 3. Choose Safe Mode with Command Prompt in the coming screen, then Press Enter.
Step 4. Wait for Windows 7 files to load until Windows login screen comes up.
Step 5. Log in with an administrator account when you see logon screen.
Step 6. A Command Prompt appears.Type net user in the Command Prompt and then hit Enter. All Windows user account names will be listed for you.
Step 7. Type net user 'Alina 123' and hit Enter.
Step 8. The new password has been successfully reset when the command is completed successfully.
Step 9. Log on your PC with the new password.
Note: 'Alina' is your locked Windows user account name. And '123' means the new password you want to reset for the locked account.
Whenever you need to log on to Safe Mode, an administrator account password is necessary. So it is highly recommended you to write Windows password down and sotre it or creating a Windows password recovery disk before lost/forgot Windows password.
Method 2: Bypass Windows password with Windows Password Unlocker
However, if you haven't created a password reset disk and forgot all administrator account password, it's better for you to bypass Windows 7 password with Windows password reset software. These reset software allow you to bypass Windows passwordwith a USB flash drive or bootable CD/DVD. Windows Password Unlocker Professional is one of the best choice to reset or change Windows password in a while.
Go through with these steps and recover Windows password with ease!
Step 1. Download Windows Password Unlocker Professional and install it in any computer.
Step 2. Run the program and burn an ISO image file into a blank CD/DVD or USB flash drive.
Step 3. Start your locked computer from the bootable CD/DVD or USB flash drive.
Step 4. bypass Windows password successfully.
Of course, there are some other methods of bypassing Windows 7 password. Picking up a suitable and efficient one to bypass Windows password is a necessity.
on Oct 28, 2010 | Computers & Internet
Hi My pendrive is write protwcted, Pendrive is
Some pen drives have a small toggle switch with them which make the drive write protected try locating that switch. If there is no such switch then try formatting the drive preferably from safe mode. you can do this by following these steps:
1. Shutdown your computer or laptop
2. Insert USB Memory Stick into your laptop or Computer
3. Turn on laptop and then immediately start pressing (Fcool.png key then Advanced Boot Options screen will come up
4. Select Safe Mode with Command Prompt
5. After loading files if your USB Memory Stick drive letter is (G) for example then write as
6. C:\windows\system32>G: and press enter
7. G:\>format G: and press enter
8. If ask you (Y/N) then press (Y) and press enter
9. Now a full format will start which remove write protection from USB Memory Stick.
Sep 23, 2013 | Kingston Technologies 512MB DataTraveler I...
\Windows\System32\Config\
Is there anything else on the error message ?
Which operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow
The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Jan 28, 2013 | HP Computers & Internet
Windows Error Reporting Error
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Dec 30, 2012 | Computers & Internet
Harmony 720 stays in safe mode then flashes when connected usb to computer
i strong recommedn to return the company. The SYScom can be faulty. see the diagram attached.
God bless you
Nov 30, 2012 | Televison & Video
How do I format a Kingston 8-GB Data Traveler 101 flash drive which is write-protected?
You can try to go to safemode (to go to safemode restart the computer then tap F8 while restarting then select Safe Mode with Command Prompt) Note: you have to have the flash drive connected before restarting After loading files if your USB Memory Stick drive letter is (F) for example then write as C:\windows\system32>F: and press enter F:\>format F: and press enter If it ask you (Y/N) then press (Y) and press enter It should reformat the usb flash drive
You can also check out the registry under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
The value should be "0".
Jul 09, 2011 | Computers & Internet
I want tell you i have sandisk 4gb when i format this usb that this massage show "window can't format this drive.." please give soluation...
try going in safe mode, make sure the drive directory is not opened, then open the command prompt and type : format x: then press Enter. Substitute "x" for the correct letter assigned for the flash drive
Sep 03, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
MicroNet New - Fantom Databank Fdb16u2 16 Gb Usb 2.0 Flash Drive - Kd2986 Logo
156 people viewed this question
Top MicroNet Computers & Internet Experts
David Payne
David Payne
Are you a MicroNet Computer and Internet Expert? Answer questions, earn points and help others
