Question about Canon imageRUNNER C3200 Copier
Cannon laser 3175 ,after copies it print activity report
I bought used this item , it was set some activity report , therefore after each copies ,it print activity report ,which i don't want ,please let me know how can i reset or diable this function . Thanks Jose
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
Yes you can go into additional fuctions button then go into reports and turn off error reporting and activity reporting, or its under communication settings
Posted on Apr 09, 2009
Cannon mf 8350 Cdn confirmation of fax report
On the printers panel:
Press the "FAX" (actual button, upper middle)
Press the "Report" (actual button, upper right)
"Report Settings" (Press OK)
"Send Results" (Press OK)
"On" (Press OK)
Jan 17, 2012 | Canon MF8350Cdn AllInOne Laser Printer
Printing an activity report
You should be able to get an activity report through the menu key. Push the menu key and scroll to reports Push ok/set key and scroll to actitvity report. Push set/ok key, one or the other, and an activity report should print out.
Jan 24, 2011 | Canon FAX-L1000 Plain Paper Laser
Hello - We have a Canon Model 3175MS Fax Machine - we want to print a comfirmation that a Fax has been sent. Is this possible? Thanks! Marcy
Yes, it is called a `transmission report' (TX report), and is a setup option.
You can change this setting with the following procedure:
Open the 1-touch panel to access the function keys.
Press the `data registration' key to access the user menu.
You should see `user settings'. Press the `set' key. Press the cursor down key to get to `report settings', and press the `set' key. You should see `TX report'. Press the `set' key. Cursor down till you see `output yes'. Press the set key.
Press the `stop' key to return to the normal screen.
It is now set to print a report after each transmission.
Oct 07, 2010 | Canon LC-3175 Laser Fax
Hello i have a panafax uf-280m i would like to
Sometimes you can go to "print reports" then activity report and print your send report
Mar 23, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
I faxed something last week and lost the transmisson verification report, can it be re-printed? does my fax keep it in memory?
It's possible to print a Fax Activity report which would show both incoming and outgoing fax activity. To do this, do the following:
  1. Press Reports
  2. Use arrow keys < > to select 3. Fax Activity
  3. Press Set
If Fax Activity hasn't been set up, do the following:
Setting the Fax Activity Report Interval
You can set the machine to print activity reports at specific intervals (EVERY 50 FAXES, 6, 12, 24 hours, 2 or 7 days). If you set the interval to OFF, you can print the report by following the Steps in the next page.
  1. Press Menu, 2, 4, 2.
  2. Press or to choose an interval,
    and then press Set.
    (If you choose 7 days, the LCD prompts you to choose a day at which to begin
    the 7-day countdown.)
I hope this enables you to recover your transmission report. Please post back with any questions or just to rate the solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
Need fax confirmation
Not an expert on this model however, on most canon fax machines the plastic cover or panel on the keypad is a door. Opening this you should see descriptions for the keys one should say report. Press report to print and follow instuctions to get activity report.
Hope this helps
Mar 12, 2009 | Canon LC-3175 Laser Fax
Test Page on Canon FAX-L220
There is no test page for the canon laser fax, the only one is to print the report list. The report list of Activity Report you cant get it by pressing the [report] button and press [set] button or if you want others report like the User Data report, Tel Registration report then press the Data Registration and press [Set] and select by pressing the Scroll Up/Down button to locate the Report setting.
May 09, 2008 | Canon L220 Plain Paper Laser Fax
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Help with setting up my cannon mx310 fax machine.
here http://www.generalmanual.com/Printers/Canon-PIXMA-MX310-Office-All-In-One-Printer.htm you can download (under "download now" near the bottom of the page) the manuals you have lost.
Hope it helped you!
Dont forget rating.
Thx.
Jan 19, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon imageRUNNER C3200 Copier Logo
143 people viewed this question
old marine
old marine
