Question about matag Maytag QuietSeries 300 Dishwasher MDB7600AWW * Metal Plastic
Float switch connections
I am replacing a float switch and wiring damaged by our angry Pekingese dog. (Really-- it's a long story) There are two wires connected to the switch terminals. One wire comes from the control panel. The other goes from the switch to the water valve. One of the switch terminals is marked "COM" The other terminal is marked "NC". Which wire is connected to which terminal?_
  • matag Master
  • 2,987 Answers
Michael Smith... Hello,
Looks like we are in luck...
My FAV website form "MANUALS"...
Happens to have your SERVICE & REPAIR manual:
Maytag JDB4000AW Service Manual
The actual description on page 29 is not all that ILLUMINATING...
... and WORSE I WAS HOPING TO SEE A circuit DRAWING to confirm what I already knew..
"Com" takes the POWERED SIDE... (hot when running)
"NC" (normally closed) goes to the WATER VALVE.
During the sequence of washing...
the controller applies power to the "COM"...
when the FLOAT SWITCH... is NOT floating power
continues to be "ON" to the WATER-VALVE...
When the water get to the operational (float)
level the "NC" (normally closed).. OPENS and shuts
OFF the WATER VALVE.
I ONLY looked halfway through the "service" manual...
before I came to the conclusion there were NO SUCH
circuit or schematic drawings... (verified on 2nd pass).
Even after to careers in electronics... I hate working on
ELECTRIC stuff... My personal pleasure would be to invite you to look at the No Contact Volt Tests... (NCVT)
Amazon com no contact volt test
For between $10 & $20 you can be the proud owner of a
NCVT... Mine is a KLEIN... (long ago.. & far away).
Turns red & chirps... when it gets near power
(so I won't have to (turn RED or chirp)).
Klein Tools NCVT 1 Non Contact Voltage Tester Electrical Tools Amazon com
Still got it... Still love it...!!
Hope this helps...
and I am glad to hear it is a long story rather than a
tragic one...!!
Give your darling Pekingese message for me...
"Wag more... chew less"
Carnac the Magnificent
Posted on Aug 01, 2017
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
I need to find history on a shih Tzu but I cant find really anything about this dog will you help me please this is due on Monday so help me FAST
The shih Tzu is a toy breed dog originated in China. The shih tzu was officially recognized by the American Kennel Club in 1969. They commonly live approx.10-16years, are lively,outgoing,playful,alert,gentle & loyal. they generally interact well with other dogs,children & adults & upon DNA analysis, have a close genetic relationship to wolves. A common character trait is they have a very noticeable underbite. I hope that helps you a little cuz thats about all I know. Good Luck!!
Oct 24, 2013 | Miscellaneous
2004 Big Dog Chopper cuts out while riding
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, stator, magneto, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Faulty or corroded kill switch.
11. Accelerator pump damaged or not working.
12. Water or dirt in the fuel system, carburetor or filter.
13. Restricted, blocked or kinked fuel line.
14. Fuel tank empty.
15. The gas cap is not venting properly or fuel tank venting system blocked, loosen gas cap and go for a test ride.
16. A failed fuel pump, pressure regulator and or fuel injectors.
17. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
18. Needle and seat stuck closed in the float bowl.
19. Petcock clogged or damaged.
20. Lean angle switch is faulty or needs adjustment.
21. Catastrophic engine failure, perform a compression test.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
power is cutting out
Big Dog Motorcycles Recall For Potential Electrical Problem
2004 Big Dog BDM Motorcycle Service manual Download Manuals Technical $15
Big Dog Parts Accessories
Big Dog Motorcycles 2005 Bulldog Owner Manual
Dec 04, 2017 | 2005 Big Dog Chopper Base
How to fix blown sub (replace fuses etc)...? stop protective light illuminitating?
The first thing to try is to disconnect the sub and all speakers from the amp's output block. The only things that you need connected to the amp are the 12V power, the ground wire, and the remote wire to turn it on. If the protection light comes on with only these three wires connected - your amp has been damaged internally and will either need to be repaired or replaced.
Jul 27, 2013 | Car Audio & Video
I put the feed dogs down and now they won't go back up, what do I do now?
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Feb 11, 2012 | Baby Lock Ellure
KENMORE DEHUMDIFIER MODEL 580.51300100 DOES NOT RUN, NO POWER LIGHT AND NO FAN RUNNING ETC
First, check the source of the power to the unit, Has a circuit breaker in your home's circuit breaker panel been tripped? If so, unplug the unit, before resetting the circuit breaker. If that's not the case, check the outlet it's plugged into. It may be damaged or have a loose wiring connection. Be sure to turn the circuit breaker for that receptacle OFF, before removing the cover plate.
If all of the above checks out OK, check the water collection bucket, as it may need to be emptied and/or the bucket was not reinstalled properly or the float valve in the top of the bucket is stuck in the UP position, If so, jiggle the arm of the float valve to get to return to the DOWN position.
When reinstalling the bucket, be sure that it fits "squarely" into it's holder and makes firm contact with the bucket safety removal switch.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 13, 2011 | Kenmore 54501 Dehumidifier
The dishwasher is stuck on drain, I think it has something to do with the overflow. Can you help? Thanks. I have checked all out lets & water in & filters.
Hi
The issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Candy 17 in. CS455 Built-in Dishwasher
MAYTAG PERFORMA PDBTT49AWW, SN 10120630ET - Under counter model, ABOUT 6 YEARS OLD. No longer gets dishes clean. Problem got progressively worse over 2 year period. After washing cycles, the inside of...
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 22, 2011 | Maytag Dishwashers
The dishwasher won't pump water in. how do we fix it?
Hello there and thank you for choosing fixya:
If there's no water entering your dishwasher, check these:
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. To determine if the float switch has failed
Aug 05, 2011 | Dishwashers
My gas guage stays on empty and the tank is full
Sounds like your senor in the gas tank it self is bad. Most cars have a float that read out how full the tank is and when it goes out it will stay stuck showing you on the dash that your tank is empty even though it is full.
Nov 03, 2010 | 2000 Buick LeSabre
matag Maytag QuietSeries 300 Dishwasher MDB7600AWW * Metal Plastic Logo
Top matag Dishwashers Experts
Are you a matag Dishwasher Expert? Answer questions, earn points and help others
