Question about Acer Aspire m5640 PC Desktop
What purpose does the battery serve in the motherboard of my desk top?
Monitor says no input
  • Acer Master
  • 2,878 Answers
It's for the CMOS chip that holds the BIOS software that supports your motherboards info. That's why you have the correct time and current hardware configuration even after being unplugged.
No input means there is no communication with the video card. Try reconnecting monitor cable. Or, possibly re-seating the video card if its an add-on.
Posted on Dec 12, 2012
Testimonial: "Now I know what the battery is for, but video card is not an add on, could it be the motherboard or hard drive?"
  • 1 more comment
  • kevin Dec 12, 2012
    What do you think?
    The video card is not an add-on, could it be the motherboard or hardrive?
  • Jose Diaz
    Jose Diaz Dec 12, 2012
    Most times it is the connection. Check that the monitor is set to correct input. There is VGA (blue plug), DVI (white), and HDMI. There is also the minute chance the on-board video might be disabled in BIOS. Press designated F key that is noted during boot to enter. Enable and save before exiting BIOS.
Where is the motherboard located on a dell dimension 3000 Desktop?
Unplugging the computer from the wall is about all you need to do to get a "cold boot". There is a battery on the motherboard you can remove for a few minutes if you need to reset the BIOS settings. That battery is about the size of a quarter coin.
The motherboard nearly fills the bottom of a desktop system, assuming it's set on the desk with the monitor on top. If you're using it as a "tower" system, the motherboard will fill one side of the box. It's big... and may have other "cards" plugged into it.
Jun 12, 2015 | Dell Computers & Internet
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
My acer veriton desk top is not booting up and giving a beep continues beep also moniter is not displyaing omething
This is likely a result of the computer not recognizing the monitor. During the POST test during startup,the computer will check for a video output. It can range from the video card failing to just not having the monitor plugged in. I would check you connections, perhaps try a different monitor, even a television that has either HDMI, DVI, or VGA input. If that does not fix it, it is likely your graphics card or on board graphics from the motherboard. Is there anything new since the last time the computer worked? How old is your PC?
Jul 10, 2012 | Computers & Internet
How to use lg 1730s lcd monitor as touch sreen for my desk top
You can't use it as a touch screen. Only for viewing purposes.
Oct 24, 2010 | LG L1730SF 17" LCD Monitor
Screen on my desk top monitor says its going into sleep mode cannot access safe mode monitor screen wont stay on long enough to do or see if anything works....,,, my pc is an hp a6500f , i replaced the...
Try using a different monitor or use that monitor on a different computer to see if the monitor is bad. It shouldn't have anything to do with your CMOS battery. I'd check to make sure the monitor itself is good before I go tearing my computer apart. Let me know how it goes and maybe we can get it figured out.
Aug 03, 2010 | E-Machines eMachines Desktop PC
Need help my desk top monitor is showing a sign flashing saying no signal detected need to see how to fix or what might be the issue with desk top
This is the message shown when you power off your computer but you leave the monitor on. If your PC is on but you still see this message then it is a video problem. It could be as simple as a loose connection somewhere in your video cable (either where it plugs into the monitor or where it plugs into the PC). It could also be the monitor-many have different input modes and maybe the input mode changed somehow. Then again something could be wrong with the video card-are components loose on it? Check all of these, in that order (easiest to hardest), and I think you will have found the problem.
Hope this helps.
May 19, 2010 | Computers & Internet
Monitor Hp w1907 has no input signal, how do I get connected and keep it from going to sleep
If you set the PC to go to sleep after certian amount of time than it will not put out signal to the monitor. You need to go to display properties (right click on the desk top)/screen saver -power/set the display to never turn off.
Nov 30, 2009 | HP w1907 LCD Monitor
My ibm desk top is stuck in power save mode monitor won't work
So the only way you have to act is, turned off and directly on the mainboard, so do it carefully.
You'll have to find out, where, on the mainboard is located the battery, (a small coin like
unpluggable metallic piece)
Remove it and let all static electricity completely disapear, so, let the cpu power unplugged,
battery removed, for 1h,
Then, place back, battery, try to start again if not working it's hardwaire failure.
Nov 20, 2008 | Computers & Internet
Monitor squiggle
if it is adjustment problem then you will have to check it with operating manual picture distortion might be due to horizontal section also if adjustment does not serve the purpose. if you are not a tech person get it done by tech person.
Oct 01, 2007 | Scanport GEM 1770DF (White) 17 in.CRT...
Acer Aspire m5640  PC Desktop Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
