Question about HP Photosmart 2575 All-In-One InkJet Printer
Black line down the middle of scanned documents.
I have a new HP 2575 photosmart. I haven't had a problem copying anything directly from the computer, but anything that I scan has a large black line down the middle.
  • haznavy Jan 20, 2009
    Same problem with nothing apparent occluding the light source on copy mode. Perfectly straight black line right down the middle of any page that I try to copy. I have reinstalled software twice and it still happens.
  • HP Master
  • 5,568 Answers
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Posted on Jan 13, 2009
  • Steve Allison
    Steve Allison Jan 13, 2009
    Forgot to mention; when making a 'sky' copy with nothing on the table, expect a page of wasted ink since it will come out black if only the scanner is at fault.
On my Photosmart 2575 all in one printer when I scan documents there is a large black line down the center. I can't figure out what's wrong. Help?
if you scan so many documents the inside of the glass or the printer is full of dirt from the inks.So you have to open it and clean it very well especially the glass.Maybe you have and a strange sound...
Jul 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
Black line down middle of scanned documents
if you have the same problem when printing any thing,t may be have a problem in your cartridges
or you have a problem in your scanner assembly (replace it)
Mar 22, 2010 | HP Photosmart 2575 All-In-One Printer,...
When I scan or copy the printer prints a black line down one side. How can I remove this line?
Have a look on the glass and make sure there is no dirt or ink or something else stuck on the glass.
Let me know how it goes.
Jan 04, 2010 | HP Photosmart 2575 All-In-One InkJet...
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black stripe down center of document
as you have cleaned the scanner glass..try these steps..
1)connect the printer to the wall outlet..
2)then try to make a copy..if you get lines..then go to next step..
3)unplug the power chord..press and hold OK and CANCEL button together..while pressing the buttons plug in the power chord..
4)after you plug in the power chord do not release the button till the screen goes blank..once its blank release the buttons and then turn on the printer..
5)try to make a copy..its still the same..it is a hardware issue..machine should be replaced
6)Call HP who would give u a rebate on old printer & replace it with brand new printer.
Mar 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Scanning
My Photosmart 2575 v has worked fine as well for over a year and now it won't scan. I get the same message: "Refer to device documentation to troubleshoot". I ran all updates and they said I have them all and everything is working perfectly. It's not though. I still can't scan. I tried their work-around by opening paint and then acquring image from the scanner but that does not work either.
Apr 30, 2008 | HP Photosmart 2575 All-In-One InkJet...
Black lines through documents
Try cleaning the cartridges to see if that helps..... mine did the same thing and after I cleaned it, it worked like new.
Feb 18, 2008 | HP Photosmart 2575 All-In-One Printer,...
Black lines when scan and copy documents
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Feb 17, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
1,215 people viewed this question
Seeker5211
Seeker5211
