Question about Tablets & eReaders
ViewSonic ViewPad 10e Wont Turn On
I just got the tablet today. was working fine for a while. I left it for a bit and when I tried to turn it back on, it would not. I put charger on but would still not turn on.
  • 2,072 Answers
It may be frozen. Try holding the power button down for 10-15 seconds.
Posted on Dec 13, 2012
msoufeer5
  • 170 Answers
SOURCE: my tablet is fully charged
battery shell is weak please replace weak shel
pls vote me
Posted on Jan 22, 2011
SOURCE: Need a manual for a Viewsonic Viewpad 1000 model
http://pdf.textfiles.com/manuals/STARINMANUALS/ViewSonic/Manuals/VP1000.pdf
Posted on Oct 05, 2009
  • 20 Answers
SOURCE: I cannot find ethernet driver
im not quite shure if this is what you are looking for but it is a Driver for a vewsonic viewpad 1000 however it is only for the operating system windows XP and below, however if you are running vista you can still try it. it is possible that it may work for vista.
you can find it and download it by following this link >
http://members.driverguide.com/driver/detail.php?driverid=334738
only thing is in order to get it youll need to select Download this file by viewing a series of ads (no registration required) and it is FREE.
Hope this solves your problem Good Luck.
Reguards: PC Pro
Posted on Dec 15, 2008
nicarta
  • 506 Answers
SOURCE: my lenovo thinkpad x61 tablet
confirm that the Power adapter is ok if the A/C indicator comes ON on the LCD on the laptop. If the A/c indicator is off replace the the power pack. Else the board may be bad, replace the board.
Posted on Aug 12, 2010
KingDWS
  • 1606 Answers
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Posted on Mar 23, 2012
Warranty check
Most of the tablets have a reset swithch. If there is not important data, you may try resetting the device.
It may be a good idea to reflash the device with its original software.
Oct 25, 2013 | ViewSonic Tablets & eReaders
My view pad 7 keeps restarting
Take a look at this..Found it with a search..You can try it.but like they say, no guarantees..try at your own risk http://www.addictivetips.com/mobile/how-to-root-viewsonic-viewpad-7-android-tablet-with-superoneclick/
Mar 12, 2013 | ViewSonic ViewPad 7 Android Tablet
Why viewsonic viewpad 7e android process won't work?
if you're using a custom ROM re-flash GAPPS. Otherwise try to factory reset
Jun 03, 2017 | ViewSonic ViewPad 7e
My viewsonic viewpad 7e wont stay on when i turn it on it shows up starting screen then turns off and just keeps doing it over and over again help plz
I think your Viewpad 7e needs to be serviced. I hope it's still under warranty.
I see the other two awesome solutions provided here: a manual for a completely different tablet and an offer for an ethernet driver you can't use.
I am actually working on a Viewpad 7e right now with the same symptom. I think it will need a new main board, but if I do come across another solution I will post it here.
Sep 22, 2012 | ViewSonic ViewPad 7e
Reset viewpad 7e tablet
my camera from my viewsonic is not working, what sould I do
Mar 04, 2012 | ViewSonic ViewPad 7e
Hi Can anyone please tell me how to transfer music from my computer to my viewsonic viewpad 7. Many thanks
put micro sd card into usb with a usb micro sd holder a put music or photos onto it/put micro sd back into viewpad slot next to sim card slot /thats it.
Oct 01, 2011 | ViewSonic ViewPad 7 7Inch Android 22...
Hello! I have ViewSonic 10. It cannot see an external HDD. It was correctly (I suppose) formatted but anyway the problem exists. It sees a USB card ok.
The problem is that the Viewpad 10 does not have enough power at the USB port to push a standard external HDD. You will need an externally powered drive or a two to one usb cable for this to work.
Jul 08, 2011 | ViewSonic ViewPad 1000 Tablet PC
Sep 09, 2009 | ViewSonic ViewPad 1000 Tablet PC
No Ethernet Controller driver!
i have the driver if you still need
Dec 15, 2008 | ViewSonic ViewPad 1000 Tablet PC
Unable to get pass login window
External HDs are not usually recognised on boot, however some external CD drives are.. although most of these type of devices have a built in recovery partition, which should allow you to restore this tablet back to factory without having to resort to loading from external devices. try pressing f10 or f11 on boot or look for other messages on bootup to press a key combination if all else fails try looking for instructions on factory reset from the manufacturers website
May 08, 2007 | ViewSonic ViewPad 1000 Tablet PC
Tablets & eReaders Logo
432 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
