Question about Philips CDR795 2-Disc CD Recorder
Spindle motor I took my cdr795/1701 2 disc recorder in and they told me I need a new spindle motor. they could not find one, but they where going out of business so they didn't have time to look.. where can I get this part.? serial #72973330 thank's
  • Philips Master
  • 5,568 Answers
The Philips parts network may be in tattered condition currently because of their abandonment of the US market, turning over everything to Funai, a Japanese maker of miserable junk.
Posted on Jan 13, 2009
Wont spin or play discs
Two possibilities, The Spindle motor need lubrication or the unit is in such condition that the pickup can not focus on the disc. This happen if the spindle platter goes out of specs- they slip down mostly. The CD olayer wants to get a Focus OK signal before the disc is told to spin.
Sep 29, 2012 | Sony Mxd-d5c Cd Changer Rare
Before you attempt to repair your DVD Player yourself, make sure that you have necessary tools and test instruments like philips screw drivers, multimeter, soldering iron, soldering lead, soldering pump, etc...
This is a DVD/MIDI Player with a "no disc error" upon loading any disc that played before...
Watch this VIDEO
First I've loaded it with disc and observe the movement of the optical lens and the spindle motor. First thing I've noticed that the spindle motor didn't oscillate upon spinning and it's spin slowly unlike the normal RPM...
I've suspected the spindle motor was already bad but still to be confirm...
Unscrew the disc holder plate from the assembly to keep away the magnet touching the spindle motor, this may affect the reading and spinning of the motor upon testing with the multimeter.
This is how it looks like after removing the disc plate holder in the assembly. Spindle motor is secured with 2 small screws in the lens assembly.
Pull-out the connectors from the main board to see the underside of the tray.
You may test the spindle motor with your multimeter set in resistance measurement (ohms X1) even connected to the small board.
Bad motor will read either less than 5ohms(shorted winding) or infinity (open winding) and will not spin.
Good motor will read more than 50 ohms(depends the size) and will spin upon testing. Watch this VIDEO.
Onced you've confirmed that the motor was already faulty, unscrew it from the lens assembly.
Replaced the spindle motor with new one. Before you install the new motor make sure that the clearance of the disc holder is the same as the old one. Compare first the clearance because if it is to high the optical lens will not read the disc same if it is to low....
After replacing the motor re-insert all the connectors to the main board.
I've load same disc which does not read a while ago and observe what will happen. Observe the disc and the sound oscillation from the spindle motor in this VIDEO.
Hope that the above information, pictures, and video will help you fixing your DVD player yourself.
Thanks for visiting Fixya.
Have a nice day!
on Apr 18, 2011 | Bose 3 2 1 GSX System
Recording error E454039000
please see your instru. manual and go to the section troubleshooting.
and fix it. God bless you
see this possibles causes.
  1. Disc loaded upside-down.
  2. Transportation lock engaged.
  3. Dirty, scratched, or defective disc.
  4. Dirty or damaged objective lens.
  5. Loading (mechanical) not completed reliably.
  6. Damaged lens suspension or damaged lens cover preventing free movement.
  7. Dirt, gummed up lubrication, or damage in sled drive mechanism.
  8. Dirty/defective limit switch or sensor.
  9. Defective spindle motor.
  10. Spindle table height incorrectly set.
  11. Bad component in optical pickup.
  12. Cracks in ribbon cable to optical pickup.
  13. Need to adjust servo (or less likely, optical) alignment.
  14. Faulty power supply, electronics, or control logic.
  15. Bad connections including missing/erratic optical deck shield.
  16. External interference.
Sep 23, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
U88 displayed on dmr es15 panasonic dvd recorder. cant play ,wipes discs ,makes grinding noises
Took off casing ,removed dvd unit. The laser runs along 2 metal spindles which i lightly oiled with wd 40. next to it runs another brass spindle which i also oiled. Re-assembled , and the machine is good as new.
Nov 14, 2009 | Panasonic Televison & Video
I recieved a dvdro4 in 2004,ijust got it out of the box.i donot have a disk in it.i cannot get the dvd door to open how can i program it?
You received it in 2004 and you just got it out of the box now????
You cannot get the dvd door to open ... but you ummm want to program it? I think you're on your way to the dvd repair shop. Or buy a new one.
Nov 04, 2009 | iLO DVDR05 DVD Recorder
I placed a DVD into the recorder /player began to vibrate & noise
I have had this kind problem before on some dvd players. I don't think there is anything wrong as such it seems you have a noisy disc motor.
My solution to this is to squirt a little WD40 where the spindle shaft goes through the motor. Don't squirt too much or it will get messy. I think you'll find this will help! (:-)
Aug 21, 2009 | Televison & Video
Hi, My Samsung DVD F1080 cannot read disc. Please, Why ?
I have 2 of these units and both suffer with spindle motor problems. With Samsungs track record with Very Bad DVD drives (2xHR734 2xDVD-F1080 + a load more I'm repairing right now) I would go with the spindle motor not spinning the disc up.
Aug 05, 2009 | Samsung DVD-F1080 DVD Player
Bush recorder no longer finds blank dvd
Owing to the fact that it works with the original discs, the set is probably ok. BUT it's not very compatible with the blank discs you've purchased. You'll have to experiment with various brands until you find those that work. I find my Cyberhome deck is not only particular with some brands, but with different batches of the same brand disc. Ask some of the big box stores that sell blanks and you'll find they get a lot of returns for the same reason, they don't work in the customer's machine. Bush doesn't sound very competent in the customer support dept, so I would look to replace your Bush recorder with something more main line, and probably more expensive and compatible.
Oh, and make sure you are getting the same type of disc- DVD-R and DVD+R are not the same.
Feb 17, 2008 | Televison & Video
First place to troubleshoot for the above listed issues are the gears, if gear driven spindle, or the belt if it is belt driven. If gear driven spindle apply enough non-attractive lubricant to the gears so they function freely. If belt driven clean all surfaces that the belt touches to ensure all dust or debris is removed and then lubricate center spindle posts only so that they can rotate freely and with as little friction as possible.
Aug 28, 2017 | Sharp Multi-System Mini Component System...
How to place the belt on the turntable.......
Pull rubber matt off TT. Use a small screw driver to pop off the small black "C" clip at base of steel record post. UNderneath plastic disc you will see the belt, and it loops on the metal post and over to the plastic barrel shaft to its right. Try this:
  1. Using Non-gelatin based nail polish remover OR acetone (gotten from any hardware store), and a few Q-Tips, rub the belt inside and out along its entire length until you feel the tacky rubber feeling come back to the belt. You may also see the shiny surface come off the belt as you clean it. The shiney look is from belt slippage and its like a glazing. Also, if you notice any of this black glazing on the two belt posts, clkean them off as well.
  2. If belt broken, replace with new by looping it back around the two posts under plastic TT platter.
If its truely a belt issue these two should solve it.
Sep 03, 2007 | Philco (R) 841.205 CD Shelf System
Philips CDR795 2-Disc CD Recorder Logo
113 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
