Question about Mitsubishi Outlander 08 2008
When should the timing belt get changed - Mitsubishi Outlander 08 2008
  • 3 Answers
Atleast every 100,000km i do mine every 80,000
Posted on Apr 11, 2013
When do i replace the timing belt on my seat inca van 2004
Those belts are usually supposed to be changed every 60,000 miles. Behind the timing belt cover is your water pump. They can make noise when going out, but usually a timing belt makes no noise, just breaks. If you ever have to change the water pump, it is always suggested to change the timing belt as well. VS. If your timing belt gets stretched, it will make a bit of a noise, but your car will start running poorly at the same time. Hope I was helpful
Jan 08, 2013 | Cars & Trucks
Need to no after how many miles we have to change the timing belt
It is recommended that a timing belt should be change every 100,000km. Honda's and Acura's especially. Whenever the water pump is changed, it is also wise to change the timing belt too as it is all in one spot, and VS. In some cars, [Acura's], when the timing belt breaks, it also can tear your valves in your engine apart, so I hope that this answers your question
Jan 04, 2013 | Cars & Trucks
My nissan pathfinder is 220,000 km, im not sure if they change the timing belt, i went to mechanic and he told me i have to change my timing belt,do i have to change my timing belt now, it works fine now
Nissan suggests the timing belt be replaced every 103,000 miles. If the belt has never been changed I would say you're living on borrowed time. This is an interference engine so if the belt fails you could end up with a seriously damaged engine.
Apr 16, 2011 | 1998 Nissan Pathfinder
Do you have to change the water pump when changing the timing belt/timing?
You don't have too, but not bad idea, the timing belt drives the water pump, if you just replace timing belt, and not water pump, water pump could go out and mess up the timing belt, now it has to be done all over again, timing belt, water pump and labor.
Sep 16, 2010 | 1996 Subaru Legacy
I have 151,000 miles on my 2002 4cyl Camry and have not changed the timeing or the sepeitine belt: Is it time to have it done?
Hi:
It is overdue time to change your timing belt and waterpump, as you are on borrowed time on the timing belt. The waterpump and tensioner should be changed along with the timing belt, as they can ruin a new timing belt if they fail. Your serpentine belt should be inspected and replaced if needed too.
Mar 24, 2010 | 2002 Toyota Camry
What else needs to be changed when doing a timing belt on a 1999 honda accord? and about how much should it cost?
Technically, nothing else needs to be changed when replacing a timing belt, however it is recommended or suggested to replace the timing belt tensioner and water pump while doing the belt. These items are only accessable when doing a timing belt. The cost should be under $100.00
Jan 22, 2010 | 1999 Honda Accord
Changing a timing belt on a 2001 Honda Accord
All of your fan belts needs to be taken off because the timing belt is located beneath the crankshaft pulley. There is a possibility that you may need to lift the motor off its motor mounts to gain access to the timing belt. Remember, the timing belt can't be seen from the outside.
Mar 08, 2009 | 2001 Honda Accord
How to fix a Timing belt
how to change a timing belt
Aug 03, 2008 | 1997 Kia Sephia
Timing belt
Timing belts are suppose to be changed every 60,000 miles.
Aug 02, 2008 | 2004 Kia Sorento
Mitsubishi Outlander 08 2008 Logo
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Mister Danger
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
