Question about Sharp LC-32SB24U 32 in. LCD TV
My tv won't come on the green power light just flashes?
    New Friend:
Push and hold the power button, i did yhat to mine and it now works,also if it comes on reset the tv
Posted on Jan 01, 2013
  • 11800 Answers
SOURCE: power & OPC lights keep
That signal the fact that the power source is in protected mode - a component has failed in the tv and now acts as a short. When the power source tries to start the failed component starts to draw so much power that the voltage drops; this trigger the protection system of the source that shuts it down to save it from frying.
To fix the tv you will need to open the tv and test the voltages on the output rails of the power source to find out which one is triggering the shut down. Then just follow it to the failed part. This requires a good electronics experience.
In your tv the most usual part to fail is the sound board: the radiator on the audio amplifier is undersized so the amplifier overheats and fries. The sound board will have to be replaced - a $250 job at a repair shop.
Posted on Jul 14, 2011
  • 20 Answers
SOURCE: tv won't turn on
you have to shut your main power down at the breaker box. It can be off for about ten min.
I hope this works for you.
?label=319qcjrupaeqnpg78wm&guid=on&script=0ep?sid%5b%5d=36973114&sid%5b%5d=30541789&sid%5b%5d=30541794&rid%5b%5d=955456&rid%5b%5d=882320&rid%5b%5d=882321&pt=ecoust2996?phint=oiqseg=36973114
Posted on Feb 11, 2012
carmine8507
  • 7 Answers
SOURCE: Flashing green power light with no picture
9-if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Posted on Nov 09, 2008
ladywinn
  • 5138 Answers
SOURCE: My tv won't turn on, it will if i hold in the
Bad capacitors on power supply board they will be vented or swollen on Top. 1000uf 2200uf 10v 3300uf 10v
Posted on May 31, 2011
diodeic
  • 1622 Answers
SOURCE: We have a 46 inch sharp tv model number 46SB54U
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Posted on Jun 25, 2011
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Toshiba TV won't turn on
Toshiba? Suspect that if it uses a Lamp for brightness (a model number would help) it may have failed----customer replaceable and if remove look to see it is not shattered inside--2 year, 2000 hour life is normal.
Oct 29, 2012 | Sony Televison & Video
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
Green flashing light on receiver of pioneer elite 434pu tv won't turn on
most likely a bad power supply and boards or service info for these sets is hard to come by. Not a do it yourself fix for most people.
Apr 22, 2012 | Televison & Video
My tv the light is flashing red green an won't
replace the power supply board. You can get replacement power supplies from www.tvcircuitboards.com
Mar 07, 2012 | LG Televison & Video
We have a 46 inch sharp tv model number 46SB54U won't turn on. The green timer light is flashing. We just replaced the power supply board thinking that was the problem. TV still won't turn on...
Jun 25, 2011 | Sharp LC46SB54U 46 in. LCD TV
Sharp LC-32SB24U 32 in. LCD TV Logo
474 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
