Question about Angelcare Ac401 Single Baby Movement Sound Monitor
Angelcare is not transmitting sound...
... Unless I am holding the nursery unit directly to my mouth and speak into it... I have already tried disconnecting and reconnecting several times... (it is new and has never worked)... Thank you!!
  • 7 Answers
SOURCE: Both units are switched on but the parents' unit
I have the same problem. I'm guessing mine is broken and will need to be replaced. However i did read a possible solution on a site with slightly different instructions to the ones in the box that describes how to pair the two devices together.
turn both the nursery and parent units off.
turn on the parent unit.
hold menu for 5 secs until it beeps.
turn on the nursery unit.
the parent unit waits for the signal then pairs.
if the nursery unit just waits 20 seconds then beep beep beeps and turns off i guess yours is broken too. I think its probably the nursery unit has stopped transmitting.
they will replace or repair a unit that less than 12 months from date of purchase with a supporting receipt.
the help line is 0845 009 1789 mon-fri 11-3pm
Posted on Jun 07, 2010
Testimonial: "it worked :)"
SOURCE: we can't remove the battery cover on the nursery
I had the same problem getting the cover off. On the bottom there is a small hole in the middle, what looks like a screw hole. I put a pen down in there and then pushed hard in the direction of the arrows on the bottom. It finally slid open.
Posted on Oct 30, 2011
In fact, it is NOT the little "screw hole" which releases it. If you push a thin pen in there you are actually bonding the cober to the base. It is the two flat plastic tabs right and loeft of the hole which need to be depressed before you pull. You need good fingernails, stick them into the line between the cover and the matching part of the base just above the tabs and pull in the direction of the arrow, making sure your thumbs are NOT holding the cover that you are trying to pull off. It really is incredibly awkward and very poor design.
Posted on Aug 26, 2012
SOURCE: angelcare movement and sound monitor doesn't work when plugged in power socket
read manual to help trouble the problem or send it in to company
Posted on Nov 26, 2012
abraao_anton
SOURCE: How to pair AngelCare AC1100 the nursery and parent unit?
thanks, this reel solve the problem
Posted on Dec 19, 2013
Can you pair a angelcare ac401 parent unit with a different nursery unit?
No the angelcare parent unit is only suitable for use with the angelcare ac401 it is designed for use with
Nov 05, 2014 | Angelcare Ac401 Single Baby Movement Sound...
Hi
We would recommend contacting Angelcare UK Customer Care on 0845 009 1789
Jul 04, 2012 | Angelcare Baby Care
The 2 units are not pairing, the parent unit just continues to flash, despite running through the re-pair process
there is a very important step missing from the previous instructions.
press the 'clear' button at the very top of the nursery unit that is part of the halo where it meets the white plastic of the unit.
every other guide i've found misses out this critical part of the process for some reason and i was just about to give up until i saw a guide on the angelcare facebook page linking to youtube showing 'extra features' of the angelcare monitor.
Sep 05, 2011 | Angelcare Ac401 Single Baby Movement Sound...
Both units are switched on but the parents' unit doesn't want to connect with the nursery unit. I clearly see the nursery unit's green light that flashed to detect movement and don't understand why my...
May 20, 2010 | Angelcare Baby Movement and Sound Monitor...
Angle care wont connect to the base
Manuals: http://www.angelcare-monitor.com/Canada/en/help
Had same problem - here's what worked for AC401 (from manual):
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Dec 20, 2009 | Angelcare 2009 Movement Sensor Baby...
Hand held monitor not working
Sounds like the units need to be paired. Start with all units off. Then turn on one of the parent units. Press and hold the menu button until it beeps. Quickly turn on the nursery unit and press and hold the button on the nursery unit that has the parent unit icon below it. After a couple of seconds the units will pair. Repeat this process with the other parent unit.
Dec 12, 2009 | Angelcare Baby Care
I droped the monitor last night and I only get to dashes appearing on the screen and it wont pick up any sound!
Manuals here: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
Nov 26, 2009 | Angelcare Deluxe Movement Sensor & Sound...
My parent unit wont do anything, it just flashes with the nursery unit simble and i can not access the menu.
Oct 16, 2009 | Angelcare Deluxe Movement Sensor & Sound...
The parent unit does not recognize that the nursery unit is on. all the correct lights are displayed on the nursery unit for normal function, but the parent unit display indicates that the nursery unit is...
Oct 10, 2009 | Bebesounds Ac401 2p Angelcare Deluxe...
My parent unit is not working. All it does is flash when it's supposed to show me the pendulum swinging, room temp etc. I have forgotten how to reset it. Help please
Oct 02, 2009 | Angelcare Deluxe Movement Sensor & Sound...
Angelcare Ac401 Single Baby Movement Sound Monitor Logo
49 people viewed this question
Top Angelcare Baby Gear Experts
Dorel UK
Dorel UK
Shehu Pro
Shehu Pro
Are you an Angelcare Baby Gear Expert? Answer questions, earn points and help others
