Question about Behringer V-Amp3
V amp 3 presets
The presets on my vamp 3 keep disappearing even after facotry reseting it it happens every alternate time i start up when i select a preset the volume and the EQ settings go to 0 and dont match what was stated on the manual on all the banks. once i do a factory rest they are back but on the next session( couple hours latter the same thing happens.. is there somthing i can do about that ?
No sound and its haming
If you mean humming, then that usually points to a power supply problem.
Jan 20, 2016 | Behringer Lx1x X Vamp Amp Multieffects...
Won't load to default
Hi Lloyd,
The introduction in the manual warns that you should ask your dealer or store in order to change the batteries. I'd suggest seeing if they have any advice.
That said, how are you trying to default the settings? I've copied the two ways below. Maybe try whichever one you haven't yet. I hope this helps.
Manual: http://hammondorganco.com/wp-content/uploads/2011/03/XK-1manual.pdf
Default #1:
In this mode, you can return entirely or partially to the default setting as set at the factory.
To locate this mode:
Touch the [MENU/EXIT] button for the MENU display, select PAGE D by the [PAGE] button, and then touch the [3] DEFAULT button. To initialize each parameter, touch the button and then [4] OK
1. ADJUST PRESET
  • Initializes the content of the Preset Key [B].
  • If the Drawbar Control mode is at "UPPER A#/B", the content of [A#] is also initialized.
  • If you do this operation before you start a new setting, you can start from the factory
  • setting.
2. PRESET
  • Initializes the content of all Combination Presets.
3. GLOBAL
  • Initializes the Global Parameters such as Master tune or assignment of the Foot Switch.
4. LESLIE
  • Initializes the content of all Cabinets.
5. ALL
  • Initializes all parameters of this keyboard.
  • If anything caused an unstable trouble on this keyboard system, the trouble would be cleared.
Default #2
Please perform the following steps to reset the XK-1 to the initial default setting.
1. Switch off the power of the XK-1.
2. Hold the [REC/JUMP] Button, and switch on the power.
3. Continue to hold down / Keep pressing the [REC/JUMP] Button until "Loading Default..." appears on the Display.
4. After 5 seconds if everything is in order, PLAY Mode appears on the Display. (Completed)
Dec 20, 2013 | Hammond XK1 Pro Drawbar Organ
X-vamp pedal only makes feedback noise
Try changing the configurations to your desired effect.
Dec 24, 2011 | Behringer Lx1x X Vamp Amp Multieffects...
How to factory reset mpd18
Heres how to restore your MPD24 factory defaults using the Vyzex software:
1. Plug in your MPD24 with USB cable, and then open the Vyzex software.
2. Click File > Open
3. Select Factory SET.SQS, and click open it.
4. You should now see BFD Lite and other details on the Vyzex MPD image.
5. As long as you're on the DATA tab, you should see a PUT SET button available. Press it to transfer the factory presets to your MPD24.
6. An overwrite warning will be displayed. Press YES to overwrite your damaged MPD24 presets with the factory presets.
You'll see a progress bar filling up for about 10 seconds, and then once it disappears, that's it!
You're all done - Enjoy!
Jul 29, 2011 | Akai Professional MPD18 Steven Slate...
Eurodesk sx3242fx has the numbers 1 & 25 flashing in the effects processor display. where can I find the code to tell me what is wrong?
Hi ! I have the same problem. THERE IS DEFINITELY something wrong there. It's not that you've not selected the effects, but the units keep on resetting. Even if you can select a different preset, it will go back to 1 & 25. I've been told that the problem has something to do with the power source, but I'm still trying to get a solution. Best luck !
Feb 09, 2011 | Behringer Eurodesk Sx3242fx Mixer Weffects...
When i press the harmony effect i have to hold it
Well i hope the latching mechanism isn't busted!
Check/review your parameter settings for your programs. Especially in the Expression Pedal Control areas.
From their site:
--Harmony Footswitch
This footswitch turns the harmonies on or off. While multiple harmonies can be selected within a preset, the HARMONY footswitch activates or deactivates any selected harmonies simultaneously.
When the LED above the HARMONY footswitch is illuminated, the harmonies are on. When the LED is turned off, the harmonies are turned off.
--Note: The settings for FX Footswitch Control, Harmony Footswitch Control and Guitar Sensitivity apply to ALL presets. The setting for the Expression Pedal Control applies to the current preset only. If you modify the Expression Pedal setting and wish to store it you must Store the preset (see page 11 ). When you load another preset, its setting for Expression Pedal Control will take effect.
--To perform a Factory Reset procedure
If you are editing a preset, press the Up or Down footswitch to exit edit mode.
Press and hold the Major/Minor button and then press and release the Store button. The display will read FAC RESET- WILL ERASE ALL YOUR PRESETS... , then STORE=RST.
Press the Store button again to continue with the factory reset. If you don’t want to do the factory reset, just wait 5 seconds, or press almost any other button, to cancel.
Mar 27, 2010 | Digi-Tech Digitech Vocalist Live 4...
I have a Fender Cyber Twin that does not save my settings. I can set up my volume,gain, treble ect.. hit save button to store the setting and if I switch settings to a different sound and back to the...
From the manual... is THIS the proceedure you are using to save the settings?
 T o SAVE:
1) Press the SAVE key once and a prompt displays the PLAYER’S
LOUNGE preset about to be replaced, (example prompt shown).
2) Rotate the DATA WHEEL to select a PLAYER’S LOUNGE preset to
overwrite with the currently active amp design
(last chance to press EXIT, cancelling the save).
3) Press the SAVE key a second time to complete the save.
Jan 24, 2010 | Music
Cyber Twin selector knob.
The selector knob may be a potentiometer or a rotary impulse giver device. In any case, it looks like the internal contacts are either dirty or oxydized so the value is changing in an erratic way which causes the unit to skip several presets at a time.
It would require a skilled technician to disassemble and clean the controller (if it can be disassembled in the first place), otherwise you will probably need to replace the preset selector knob entirely.
Regards,
Triarcuate
Oct 07, 2009 | Music
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Behringer V-Amp3 Logo
63 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
