Question about MSI MEGA 865 (MP865P30520) PC Desktop
Mega 865 turns off after 30 seconds
My Mega 865 just died. When I restart the harddrive it turns off after 20-30 seconds. Even if I try to start Ubuntu from dvd the computer just shuts down after a few seconds.
Definately a hardware problem but I don't have a backup. What to do?
    Genius:
  • 1,066 Answers
Prolly your power supply
Posted on Feb 01, 2009
93 toyota pickup 4x4 it will stay running after I turn it on to start it up, it starts up then after a few seconds it kills
if I'm reading this right...
... the engine starts and dies within a few seconds.
... you jumpered the fuel pump test connector and it will keep running.
... you smell fuel after trying to re-start when it dies.
Disconnect the plug to the cold start injector. Even if you have an issue with the engine running then dying after a few seconds after doing this, if you don't smell fuel after disconnecting the cold start injector and try to restart it, the cold start time injector time switch may be failing.
Buy a can of starting fluid and have someone start the engine then spray short bursts of the fluid around all the intake fittings. If spraying the fluid in any particular area keeps the engine running, I'd start looking for leaks around that area.
It does sound like an AFM or COR issue considering it dies after a few seconds, but the fuel smell when trying to restart the engine may be a separate issue that needs corrected / isolated first.it will keep running.
Mar 30, 2013 | Cars & Trucks
Hi my name is joe i bought a used mega 865 pc the radio and cd player work fine but the computer will not post or boot keybord flashes when turned on i installed a new hard drive,dvd drive and also put a...
There are separate buttons for power, one for hi-fi, another for the PC. They are above and below the big knob. The top one is hi-fi, the one below the big knob is PC power. Have you tried both?
Sep 29, 2017 | MSI MEGA 865 (MP865P30520) PC Desktop
Car dies
it's probably either the inline fuel filter or could be the pump in the tank,i would try replacing the line filter first(NOT TO EXPENCIVETO REPLACE)try driving it around awhile see if that works 1'st.rate this .thank's
May 27, 2009 | 1994 Pontiac Firebird
Error message power cable not connected to video card G manual
Power off your pc eject all cable then plugin again, if still not working try to change new cable. Some problem, video card not full insert.
Apr 11, 2009 | MSI MEGA 865 (MP865P30520) PC Desktop
Car dying after 30 minutes of driving
sounds to me like the computer is acting up on you. i would have it checked
Jan 25, 2009 | 1989 Ford Thunderbird
Starts on first pull. Runs about 30 seconds and dies.
Found the air filters on both mowers were so saturated with oil there was not enough air getting to the carburetor. Cleaned the filters first with dishwasher detergent and hot water, dried them, then soaked them in aclcohol to remove more oil. Dried filters, installed on mowers, and both mowers now run fine.
Jan 17, 2009 | Garden
Starts ok, but if turn of, will not restart
Try replacing the coolant temp switch. The one that sends signal to the ECU. I hope this helps
Nov 14, 2008 | 1994 Jeep Grand Cherokee
1999 toyota tacoma Sr5 won't start
Check for fuel pressure when starting. Fuel pumps have a check valve in them that keep fuel in the rail at the injectors. If the check valve fails, the pump has to pump fuel all of the way up to the engine. Same thing with hot no-restarts. Fuel pump.
Aug 08, 2008 | 1995 Toyota Tacoma
MSI MEGA 865 (MP865P30520) PC Desktop Logo
153 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
