Question about Beverage-Air BM23
I have a very old Beverage air DD-22 beer dispenser. I think it now goes by BM-23 When I plug it in I get a shorting out sound and the smell of something burning. My question is is the compressor failing and is it worth fixing?
  • Beverage-Air Master
  • 4,654 Answers
Yje compressor is probly what is causing the shorting out signs you decribed. If the compressor has shorted it in not worth the money and time to replace. Do you have an OHM meter? Below is how to test the compressor.
Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Posted on Dec 12, 2012
2 Suggested Answers
SOURCE: I have a bm 23
This may be due to compressor over working. A dity condensor, or runing power cord on a excored, compressor is pulling high amps and will damage compressor. You can replace bad parts and rewire. You need to have someone check amp as compressor starts up and as it runs. If it trips the over load on start up compressor bad. has grounded out.
Posted on Oct 18, 2010
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
How do I get the right temperature in a beverage air BM 23 Kegerator
either a problem with the thermostat or the probe for it has been dislodged and getting a false temp reading
May 18, 2014 | Beverage-Air BM23
I have a bm 23 beer dispenser, wiring and relays burned up on the compressor, have any reasons why? is compressor shot?
Oct 17, 2010 | Beverage-Air BM23
I have a Beverage Air Beer Dispenser Model # DD235-GC I fill with condensation when running. Don't see any way to deal with the water. Machine was purchased in 1960
it is just condensation,so if it aint got a drain hole you will need to put silica gel cristals in a cloth bag to soak up condensate.and dry them in the oven as normal.....
Jun 14, 2010 | Beverage-Air BEVBM23 Commercial Beverage...
Have commercial beverage air kegerator that keeps tripping fuses when plugged in, what's wrong
There is 2 kind of compressor location on those beer coolers. I have video of both. Hope that helps.
Oct 25, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
When the beer dispenses it has way too much head.
try adjusting your co2 pressure down a litle bit it should help
Dec 12, 2007 | Beverage-Air BEVBM23 Commercial Beverage...
Beverage-Air BM23 Logo
175 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
