Question about Hardware & Accessories
Noma outdoor timer 052-8845-8
Directions say toet on time pull segment pins down to time ON cant locate segment pins,Where are they?
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Posted on Dec 14, 2008
SOURCE: The instructions indicate to push
Generally the segments are already pushed down when you buy timer.
Instruction usually say, pull up all the segments, and after pulling up all the segments, then push down the segments for the hours you want the timer turned OFF or ON depending on timer
51ec3fc.jpgSegments on GE 15207 timer
Posted on Oct 13, 2010
SOURCE: How to set a Noma outdoor timer
You posted under Noma timer.
Noma timers are one of the names used for Woods timers.
You posted under 6-button outdoor timer.
Here is a link to 6 button outdoor Woods timer, to help identify your timer.
If this is not your timer, scroll through page to identify timer.
Manuals are posted with each timer, add a comment with specific timer number if you want me to write out steps from the manual once you identify the timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
geno_3245_173.jpg 6 button outdoor 7-day timer
geno_3245_174.jpg 6 button outdoor Week timer
Posted on Dec 11, 2010
SOURCE: LOST INSTRUCTIONS NOMA OUTDOOR TIMER # ET525C
UPM makes ET525 timer.
http://waterheatertimer.org/UPM-timers-and-manuals.html
ET525 manual is 3.6 MB and takes a bit to download on lower speed connection.
http://waterheatertimer.org/pdf/UPM-ET525C-heavy-duty.pdf
Posted on Dec 12, 2010
SOURCE: i have a noma outdoor digital timer, model n1502.
Link below has photo of timer to confirm correct timer.
Manual and other information also show about timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 24, 2011
We can't figure out how to set our timer. Where and what are the segmented pins. Nothing is labeled. There is no diagram with the timer. Thank-you. Joy and Fred.
Hi Joy and Fred.
You posted under Woods outdoor timer, but don't give specific brand or model
Open following links for detailed information and illustrations:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#59383
Segments are usually on outer edge of dial.
Some timers the segments lift up, some push down, some pull up and out, etc.
Use a fingernail or small tool and fiddle around with it.
Some timers have pins located on dial face that click inward or outward. Use small tool and move them in and out.
Some timers have trippers that you attach to outer edge of dial.
If you are confused, open links above for illustrations.
After moving some segments-pins. Plug lamp into timer.
Turn lamp on. Plug timer into outlet.
Manually rotate timer dial and watch how lamp turns on-off.
Move timer switch both directions and manually rotate dial to see lamp turn on-off.
These tests will show you how to set pin-segments-trippers and switch for your specific timer.
The timer dial rotates as time passes. The dial is a simple clock that rotates because of a clock motor.
The dial causes segments-pins move small lever that turns lamp on-off.
Just like any clock, the correct time has to be set. To do this: rotate dial until current time lines up with arrowhead located on inner dial.
For more information, add a comment with in-focus photo of your timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Apr 29, 2011 | Woods Outdoor 24 Hour Mechanical Heavy...
How do i pull the segment pins up on a woods 1702 timer for the off time
Following link shows types of segments and pins:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
The Woods 1702 outdoor timer has segments that are 'similar' to the second photo from left.
I test these timers, and the segments and pins are small.
Segments can be pried up using fingernail file.
Sometimes the segments also pull outward and not straight up.
Each timer is a bit different.
Dec 21, 2010 | Hardware & Accessories
How many minutes does each pin represent?
You posted under Woods 59383 outdoor timer with 500 watt capacity.
This is a 7-day timer with segments (or pins) located around outer edge of dial.
Pull segments up to set OFF times.
Leave segments down for ON times.
Image of timer:
http://waterheatertimer.org/images/Woods-59383-image-500.jpg
Looking closely at image, there are 12 segments for each day.
So each on-off segment is 2 hours.
The dial shows days of week.
For example Monday (MON).
MON appears at 12 noon Monday.
TUE appears at 12 noon Tuesday
Rotate dial until current time lines up with arrowhead.
If this is not your timer, see all Woods timers and manuals:
Dec 13, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
I cannot figure out how to set my outdoor timer to control my Christmas lights. How do I set the pins?
There are 4 basic pins/tabs/segments for timers
Pins move back and forth
Segments lift up
Segments pull out
Segments push down
Each type of pins/segments are located on dial.
Dial rotates as time passes.
The pins/segments contact on-off lever and cause lever to move.
Lever movement opens and closes electrical contacts.
The little plastic parts and motors wear out.
Make sure pins/segments are pushed all the way into place.
Check override switch is clicked to TIMER
Rotate dial until current time lines up with arrowhead marker
To check operation of timer, manually rotate dial to watch lights turn on-off.
Troubleshoot:
Lights must be on.
Bulbs are good.
Receptacle has power.
Check timer in different receptacle.
If dial does not rotate or pins/segments don't turn lights on-off, timer might be bad.
Dec 12, 2010 | Garden
Where are the "never-lose pins"
Woods 59204 manual says pins, and I think the timer has tabs or segments instead.
These are located on the rotating part of dial.
Look at pictures on following link to see 4 basic pin-tab-segment layouts that are used to turn these timers on and off: It's likely that your timer will be one of these.
Some timers have pins that click in and out
Some have segments that pull up
Some have segments that pull out
Some have segments that push down
Add a comment any time.
The phrase 'never-lose' means the pin-tab-segment is permanently attached to the timer dial.
Older timers, and many box timers have loose pins or trippers that you attach to the timer dial ... and of course people lose these trippers and are constantly searching for their model number of tripper which is not available. And some of these older timers were expensive. For example the older style malibu power packs have trippers, but when the tripper wears out, there are no replacements and power packs are expensive.
Dec 11, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
How do you pull the pins up to turn timer off?
You posted under Woods 59204, but Woods makes different timers with same number and others timers with multiple numbers
If this is not your timer, add a comment
http://waterheatertimer.org/pdf/Woods-59204.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59204
Manual for 59204 says segments are located around edge of dial.
Pull segments out with fingernail or small screwdriver to set on off times.
Here are some photos
There are two 2 basic types: Pins and segments
geno_3245_152.jpgTimer pins flip in and out using fingernail.
geno_3245_153.jpgTimer segments lift up using small tool or fingernail
geno_3245_154.jpgSometimes segments pull outward away from center
To check timer functions after setting pins or segments,
manually rotate dial to and watch lights turn on and off
Dec 08, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Where are the pins on the 59382 outdoor timer
The 'segment pins' mentioned in manual are tiny segments located around outer edge of dial.
There are 4 segments per each hour.
Each segment represents 15 minutes.
Use small screwdriver or fingernail to pull segment up.
When segment is up, timer is OFF
Leave segment down, timer is ON
Timer is 500 Watt.
Timer handles maximum 20 strings of 50 mini-bulb Christmas lights
Dec 06, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
How do you set the timer
You posted under mechanical outdoor timer with time dial located on face.
If you have different timer, add a comment.
Instructions:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There are segments or pins located around outer edge of dial.
If timer has segments.
Pull these segments outward, or leave them in place to set on-off times.
Pull out a few segments and then rotate dial clockwise to see if lights turn on or off with segments out.
Then pull out segments for the times you want timer to turn on-off.
If timer has pins.
Click pins outward, or leave them in place to set on-off times.
Click out a few pins and then rotate dial clockwise to see if lights turn on or off with pins out.
Then pull out pins for the times you want timer to turn on-off.
Some timers also have an override button located on inner dial or somewhere on body of timer.
Move this switch to TIMER or AUTO, depending on your timer
Dec 05, 2010 | Stanley 38445 TimeIt 24Hour Daily Outdoor...
Lost direction on how to set the timer
Manual for 59383:
http://waterheatertimer.org/pdf/Woods-59383.pdf
If you have different model Woods timer, see link below, or add a comment.
To set Woods 59383:
Segments located around dial control on-off times.
Pull segments UP for OFF times.
Leave segments DOWN for ON times
Set manual override switch to arrow-down position
Switch unit to ON position.
Plug in timer.
Plug lights into timer.
If lights have switch, switch must be ON.
Max load 500 watts
50-mini-bulb string of Christmas lights is 25 watts
Dec 01, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
I can't find the pins that the instructions refer to.
Woods timers:
1) You posted question under Woods 59383 which has segments located around edge of dial.
These segments are pulled up to set OFF times.
Segments are left in down position for ON times.
2) Other Woods timers have tiny pins that stick up on the dial.
Pins are located on part of dial that rotates.
Get your glasses.
Run your finger across the dial and you can feel tiny metal pins that stick up.
Dial has 48 pins. Each represents 1/2 hour.
Use fingernail to move pins outward from center of dial.
Pins out = timer ON
Pins inward = timer OFF
Below are 2 EXAMPLES of Woods timer showing pins and segments
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Hardware & Accessories Logo
1,612 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
