Question about Whirlpool Refrigerators
We have a Whirlpool model ED5shaxmb10 that the freezer is working fine and the ice maker works but the fridge portion is not as cool as it should be, it is only 42 degrees at the highest setting
  • Whirlpool Master
  • 4,655 Answers
You most likely a defrost problem. Look into the back of the freezer and see if you have frost building on the rear panel like in the photo=> HERE
The most likely part that will need replaced is the=> W10351625 Defrost Control Board
We have a Whirlpool model ED5shaxmb10 that the fre - 12_12_2012_8_40_54_pm.jpg
The next most likely parts that may be defective are the=> 2323198 Defrost Heater Assembly
and the=> W1We have a Whirlpool model ED5shaxmb10 that the fre - 12_12_2012_8_49_07_pm.jpgt
Like I said the defrost control board is the most likely part to fail and cause defrost to stop working. The defrost control can be found behind the control panel inside the fresh food section just above the top shelf. I am here to anser any more questions should you need answers, Thanks Sea Breeze
Posted on Dec 12, 2012
I have a problem. My refrigerator side is freezing where is getting the cold and all my food is getting bad because it is not getting enough cold. I need help!
Posted on Dec 27, 2012
dididsaythat
  • 291 Answers
SOURCE: Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Posted on Sep 03, 2007
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
  • 9 Answers
SOURCE: Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Posted on Sep 06, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
  • 1122 Answers
SOURCE: Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Posted on Mar 15, 2009
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
Our Whirlpool refrigerator model ED5SHAXMB10 is keeping our freezer food cold, yet no cold air is being blown into the refrigerator. Refrigerator is getting very warm. What can be done to fix it?
The defrost is not taking place on time or the defrost ventilation door is stuck closed.Its controlled by motor,that motor is got faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Refrigerator set on 5 the coldest and there is a water dripping
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore fridge not cooling
check for your freezer fan running properly
then check to make sure you have air flow into the freezer this model has a habit of freezing ice in the air channels
Oct 07, 2009 | Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
I own a three year old Whirlpool side by side fridge freezer with ice maker and water dispenser. Icemaker not now working, and fridge temperature warmer, not cooling food etc sufficiently
ice maker will not work,i push the handle to get ice it makes a noise like the motor is running .the water works just fine .please any ideas
Jun 28, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
545 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
