Question about Dinosaur D Rex Interactive Robot Remote Control Pet
D rex has stopped walking , makes a buzzing sound like he,s trying to walk and batteries are new need him repaired where do i find one thank you lori
You can email me at lcwalton@live.com please if any one can help thank you
Welt foot for rex single needle walking foot for a rex not singer not consew not brother juki but for a rex
You can check with http://www.shop.heavysew.com/Rex_c109.htm if you don't find it on there site call them Heavy Sew com Online Shop
Apr 20, 2017 | Singer Sewing Machines
WHERE CAN I BUY A WALKING FOOT FOR MY RX-1804.
The Janome even feed foot will work with your machine
http://janome.com/en/accessories/sewing-machine-feet/even-feed-foot/
Jan 08, 2015 | Rex RX-1804
D-rex dinosaur doesn't walk
You may have to conclude D-rex is defective. I have had similar experience with other complex toys.
Jan 16, 2014 | Dinosaur D-rex Interactive Dinosaur By...
When i start running it isnt a steady flow of the belt there is jerks every few seconds making it very hard to run and almost is enough to make you fall what do you think the problem might be
It sounds like you either have a loose walk belt or a slipping front drive pully. The walk belt shoould be tightened so that you can pull up on the edge of the belt about 2 inches. If that is OK, pull the motor cover, start the treadmill and walk trying to stop the belt with you feet. Watch the drive belt this time (the small one going from the drive motor to the front drive roller), if this belt stops, you need to tighten motor, or replace if it is older/wornout. If the drive belt keeps turning fine, watch the front roller and see if the pully connected to the drive belt keeps turning while the roller connected to the walk belt stops, if so you need a new front drive roller.
Hope this helps
Nov 03, 2010 | Epic View 550 Treadmill
Dryer won't start-Get a buzzing sound when pressing Start
Sounds like motor cost any where from $100 to $150
maybe a little cheaper if find the right place
Apr 24, 2010 | Dryers
I have a maytag side by side frig. Today I walked
Below is 2 links you can click to view the fountain. Thanks, Sea Breeze I believe that your board ot the water solenoid is defective.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171257
http://servicepartstec.blogspot.com/ Enter model number on this link, they also offer free assistance. Model number MSD2735GRS
Apr 30, 2009 | Maytag MSD2736GR Side by Side Refrigerator
In need of welt foot for rex 26-188 sewing machine. Is there one that is available for another machine that will work?
Well I'm not sure if this is a solution but, most walking foot machines are either like the Juki 562 or 3 and the Singer 111, 211  or newer models. REX's are particularly original, they should be using a very similar welting foot. Many industrial sewing stores in LA have them.. Kyle
Mar 26, 2009 | Rex Sewing Machines
RCA RT2500 Buzzing Sound - Replace 6800uv 16v caps
I did it. I decided to go ahead with the repair myself. I have never done something like this before but it was easier than I thought. I filed off the old parts and soldered on the new. It works like a charm. Thanks.
Mar 14, 2008 | RCA RT2500 System
MP 3 player and noise
try different headphones and/or new battery. buzzing is usually a short/bad/dirty connection somewhere.
Jan 20, 2008 | Panasonic SV-MP020 MP3 Player
Dinosaur D Rex Interactive Robot  Remote Control Pet Logo
49 people viewed this question
Top Dinosaur Toys Experts
ray gallant
Are you a Dinosaur Toy Expert? Answer questions, earn points and help others
