Question about E-Machines T5212 PC Desktop
Power button faulty
Power button stays pressed down
  • E-Machines Master
  • 7,627 Answers
Can you remove the front cover, access the rear of the button, clean, use silicon spray/ repair. Sometimes the plastic retainer/spring will break and not return the button to the out position.
Posted on Dec 13, 2012
Phone wont hard reset
If this doesn't work, you need to return it.
Performing a factory reset using hardware buttons
  1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
  2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
  3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
If that doesn't
Oct 16, 2016 | HTC Cell Phones
Hp dv5 HP logo stay on after its shut down and the volume lights stays on the dvd player can eject after the laptop is shhut down, how to remedy this.
Force shutdown ur laptop by pressing and holding power button for 10 sec.Remove ur battery and power adaptor.Remove DVD drive and try to power on and shutdown laptop if the problem is solved ur dvd drive will be faulty if problem continues try to remove wifi card and shutdown.to remove wifi card go to http://www.youtube.com/watch?v=Wr1Ra1qxC74 and watch it go to time 3:50. in that video u will get how to remove wifi.remove wifi and place aside and try to switch on and shutdown ur laptop.If laptop is shutdown properly then wifi card will be faulty.Update me the status if u still got the problem.Cheers....Jerine Kunjachan HP Pavilion DV5 Full Disassembly Nothing Left Out
Sep 28, 2014 | HP Computers & Internet
Mg 5350 6502
Solution 1:
  • Unplug the printer.
  • Remove the faulty Cartridge
  • Plug in the printer and press and hold power button
  • Keep it held down. Press Resume twice, and this should reset the fault.
Solution 2:
  • The last cartridge installed may be faulty.
  • Install a new cartridge
Solution 3:
  • When error is indicated, turn power switch off so green light is extinguished.
  • Hold down resume button and hold down power button so both are held down at same time
  • When green light comes on, continue holding down power button and let resume button go, then press resume button twice.
  • Let power button go.
  • Press resume button four times, power button should be released before doing this.
  • Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on.
Nov 21, 2013 | Canon Office Equipment & Supplies
Computer will not start
Press power button down for 5seconds until the computer shuts down. Remove power cable, press power button down 10s. Connect cable, try to restart.
Aug 17, 2012 | Dell Computers & Internet
I WAS HAVING PROBLEMS WITH OVER HEATING, NOW MY LAPTOP HAS CUT OUT AND WONT RE-START. WHEN YOU PRESS THE POWER BUTTON IT LIGHTS UP AND YOU CAN HEAR THE FAN OR SOMETHING BUT THE SCREEN STAYS BLANK. ALSO...
When a laptop overheats the CPU will shutdown, this is known as thermal overload. The laptop will not boot up until the CPU has cooled down. If this problem in not fixed then the CPU will eventually fail.
This problem is usually caused by a faulty fan or the fan and heat sink is clogged with dust.
Replace the fan if it does not spin freely and or remove the dust clogging the fan and heat sink.
Oct 27, 2010 | Compaq Presario CQ60-220US PC Laptop
Asko dryer model#7005 when i start the dryer i push the start button and let it go it does not stay on. If i hold the start button down the dryer will stay running.
Hi There, Sounds like there is a relay switch that may be faulty, the power should latch on when you press the start button, I am unsure of this model type, but usually there is a small PCB inside the unit behind the facia, remove the top to expose it, and you can either replace the PCB or replace the relay the latter being cheaper but more work as you will have to reflow and solder the relay
Nov 27, 2009 | Asko Dryers
Pc keeps randomly powering off & then back on. Won't stop until I unplug it.Holding down power button won't shut it off. On occasion it will stay on - is able to boot & be used normally while it...
Power supplies usually are culprits in random shut downs, but random start ups is a bit more complicated. You say that when you hold the power button, the computer won't power down. Perhaps you have a faulty switch? Make sure your PW switch cable is securely attached to the motherboard. But I'm leaning more toward a faulty switch or a short in the wires. Seems like a good place to start.
Sep 05, 2009 | E-Machines eMachines Desktop PC
Power working but won't stay on
sounds like u have a faulty start button. the switch isn't staying closed...
Feb 22, 2009 | Whirlpool LER4634J Electric Dryer
Not working
This maybe down to a faulty cartridge replace cartridges and then retry. You can try the following to obtain a test sheet.
  • Turn on printer
  • Hold power button down (While printer is on)
  • Press the paper feed button once
  • Release both buttons
This will printout a test sheet but I really do think that it is a faulty cartridge problem.
Hope I could help
Thanks J
Dec 08, 2007 | HP DeskJet 1220c InkJet Printer
E-Machines T5212 PC Desktop Logo
27 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
