Question about Bang Olufsen Bang Olufsen BeoCom 2 24 GHz 2Line Cordless Phone
How to replace battery for Beocom 2 - Bang Olufsen Bang Olufsen BeoCom 2 24 GHz 2Line Cordless Phone
How to change the battery of Beocom 5 handset?
contact Beocom it might have to be sent to them to change out
Dec 10, 2017 | Lands Phones
Opening a beocom 2 table charger
There could be a screw hidden under the sticker.
Aug 19, 2016 | Bang & Olufsen Olufsen BeoCom 2 Table...
Battery does not chrge in handset
Could be the connections on the bottom of the phone need cleaning. Use a pencil eraser to clean the connections in the cradle and on the bottom of the phone.
May 21, 2015 | Lands Phones
Handset shows line busy
its not syncing to your phone the right way.
Aug 15, 2013 | HQRP Phone Battery fits BANG & OLUFSEN...
Beocom 6000 line busy
BeoCom 6000 is a cordless system phone with advanced features and elegant design
May 19, 2012 | Office Equipment & Supplies
How do I replace the battery on my Bang and Olfsun BeoCom 2 hand set
The battery retaining clip assembly sits inside a groove that holds it in place. Do not try to pry it you'll probably break it into many pieces. Using a retaining spring pliers, insert the pliers two prongs into the two tooling holes in the assembly and squeeze it so the clip assembly clears the groove ledge. It will come out slowly. Replace the battery. Assembly is the reverse.
Nov 22, 2011 | Bang Olufsen Bang Olufsen BeoCom 2 24 GHz...
My Beocom 6000 table base unit no longer charges
If your base has a charge indicator on it and it indicates that the handset is charging when the handset is in the cradle, I would say you need a new battery. RadioShack sells a replacement battery for $22.00 at the following link
http://www.radioshack.com/product/index.jsp?productId=2815547&CAWELAID=107599274
If the charge indicator doesn't come on it is unlikely that it is the battery. You may be able to get the phone repaired by the manufacturer but it may be better and more practical to get a new phone.
Jan 07, 2010 | Lands Phones
New Battery will not charge up on a Beocom 6000 cordless phone.
The original battery package was 3x 1.5v AAA in series, giving 4.5v. Red off the (+1). Black off the (-3). A 47k resistor also came off (-3) to feed the third wire. The new battery packages are the same with one exception. The 47k resistor has been replaced with what looks like a 10k thermistor. I cut it out, soldered a 51k resistor in its place, sorted! Fully charges, as per expectation.
Dec 01, 2009 | Lands Phones
Problem with B&O beocom 6000 ''extension'' no contact with base
I think you just need to re-register the phone to the base. Press the button on the base station (between the 2 charger pins) then go to the handset setup menu, scroll to register handset.
Feb 25, 2009 | Lands Phones
Bang  Olufsen Bang Olufsen BeoCom 2 24 GHz 2Line Cordless Phone Logo
199 people viewed this question
Top Bang Olufsen Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Bang Olufsen Lands Phone Expert? Answer questions, earn points and help others
