Directions say pull segment pins up to on position that you require . Where are segment pins?
SOURCE: Noma Timer Model #ET525C - Require Instructions
ET525C is UPM timer
http://waterheatertimer.org/UPM-timers-and-manuals.html
UPM ET525C Manual
http://waterheatertimer.org/pdf/UPM-ET525C-heavy-duty.pdf
Instructions are 14 pages. It is impractical to re-write 14 pages of instructions.
If you have a problem, add a comment and say exactly which programming you want to set, and I will respond.
-Timer can be programmed for ON and OFF times, for Dawn-Dusk, for Countdown, for Daylight countdown, for daylight saving, and for Random. Each different programming option has 8-12 steps shown in manual.
SOURCE: how do i pull the
Following link shows types of segments and pins:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
The Woods 1702 outdoor timer has segments that are 'similar' to the second photo from left.
I test these timers, and the segments and pins are small.
Segments can be pried up using fingernail file.
Sometimes the segments also pull outward and not straight up.
Each timer is a bit different.
SOURCE: Require instruction how to program
I show Everflourish EMT 757
Open following link to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: We can't figure out how
Hi Joy and Fred.
You posted under Woods outdoor timer, but don't give specific brand or model
Open following links for detailed information and illustrations:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#59383
Segments are usually on outer edge of dial.
Some timers the segments lift up, some push down, some pull up and out, etc.
Use a fingernail or small tool and fiddle around with it.
Some timers have pins located on dial face that click inward or outward. Use small tool and move them in and out.
Some timers have trippers that you attach to outer edge of dial.
If you are confused, open links above for illustrations.
After moving some segments-pins. Plug lamp into timer.
Turn lamp on. Plug timer into outlet.
Manually rotate timer dial and watch how lamp turns on-off.
Move timer switch both directions and manually rotate dial to see lamp turn on-off.
These tests will show you how to set pin-segments-trippers and switch for your specific timer.
The timer dial rotates as time passes. The dial is a simple clock that rotates because of a clock motor.
The dial causes segments-pins move small lever that turns lamp on-off.
Just like any clock, the correct time has to be set. To do this: rotate dial until current time lines up with arrowhead located on inner dial.
For more information, add a comment with in-focus photo of your timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
