Question about Sharp R-9H66 Microwave Oven
Sharp R402JK-T sparking on starting
When starting oven sparking and smoke occurs on right side of microwave. Dimming looks like it occurs also.
    Top Expert:
  • Sharp Master
  • 14,553 Answers
Unplug the unit and do not plug it back, I can almost picture someone doing this, watching the sparks and smoke and oh the lights dim--Be smart here===either replace it out of hand or take to a repair shop to see if worth fixing or not and do not attempt to turn it on again.
Posted on Dec 13, 2012
  • 833 Answers
SOURCE: microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
EwingElect
  • 276 Answers
SOURCE: Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Posted on Mar 25, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R403 microwave internal electrical short/fire
This is a simple problem & solution.
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Since your waveguide cover is damaged, it will need to be replaced. It provides important protection for the magnetron.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jun 04, 2009
SOURCE: Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Posted on Dec 14, 2009
Sharp carousel microwave
Sometimes, bits of food get behind the microwave generator mica cover and cause this EXACT problem they short out the microwave energy and spark. . It is NOT broken but DONT let this happen for more than a few seconds. !!!! You will see the Mica (looks like plastic) cover from inside the oven and will be on one of the sides.It looks oblong normally, It is actually transparent to Microwaves and is how they get from the generator in to the oven. Give it a real good clean around the edges or better still take it out to clean. and it should be fine
Aug 25, 2014 | Sharp Carousel R530EST Microwave Oven
Sharp carousel R 430 EK 1200 watts
This is not good, the magnetron is arcing because metal is exposed, this will eventually destroy the magnetron making the oven useless. I strongly suggest it get looked at for safety and potential fire hazard.
Mar 05, 2012 | Sharp Carousel R530EST Microwave Oven
I have a Sylvania Microwave oven Model # SM81004/SM81001 1.0 cu.ft. It started sparking during reheating a plate of food only after about 1 Minute. The metal plate on the right side looks like it has a...
You should replace the waveguide cover, the plate you refer to. They are fairly cheap and easy to replace.
www.espares.co.uk or www.cpc.co.uk most appliance repair services can get them.
Mar 08, 2011 | Sharp R-820B Convection/Microwave Oven
Fire sparks when in use off pad on right side of microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jul 09, 2010 | Dacor DMT2420SS Microwave Oven
Microwave ovens
Dec 16, 2007 | Sharp R-1480 Microwave Oven
Microwave
check inside the microwave oven , at high voltage section wiring probem, change the wiring, and magnetron, other related spares.
Nov 03, 2007 | GE Advantium SCA2001BSS Microwave Oven
Sharp selling bad microwaves
paddy paddy paddy i want i want, bet you were spoiled as a child, never continue to use a microwave that sparks, you can only do more damage to the appliance and maybe even worse is this sparking when you use it under normal conditions, place a plastic bowl with cold water in and see if it sparks then, if not then is it something you have done, i assume you know what you can not put in a microwave if sparking occurs anyway, and its only 6 months old, is it under guarantee, then its simple, send it back and ask for free replacement SHOUT AT THE RIGHT PEOPLE DON'T WASTE TIME ON HERE
Oct 04, 2007 | Sharp R-220BW Microwave Oven
Microwave Ovens Logo
136 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
