Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Brush Bar not turning on a bissell pro heat 2x
  • Bissell Master
  • 18,402 Answers
Here is the Instruction or User Manual for the 9500 series machines
will give instructions how to check and change drive delts
Posted on Dec 12, 2012
SOURCE: bissel pro heat 2x wont spray any water
I had the exact same problem with my ProHeat 2. It would spray only through the hose attachment but not on the floor. Cleaning of the spray endings on the floor unit fixed my problem. Either soap deposits or dirt was clogging the spray endings. Here is what to do to clean up the spray endings:
1. Remove the water container from the bottom unit
2. Look up for two red plastic endings on the bottom unit
3. Using your fingers to clip sides of an ending, carefully remove it from its slot
4. Using pliers, release the clamp from plastic ending and remove the red plastic ending from the hose
5. Clean the ending
6. Put the ending back on the hose, slide clamp back on the ending
7. Insert the ending back in its slot
8. Repeat 3-7 for the other ending
That solved the problem for me!
Posted on May 17, 2009
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
SOURCE: Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Posted on Jul 12, 2009
  • 17 Answers
SOURCE: my bissell pro heat 2x will not spray water to
Here is the fix
Posted on Feb 08, 2010
  • 20 Answers
SOURCE: My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Posted on Apr 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell proheat 2x troubleshooting
depends on the suction capability generally the are slower than the bottom as you don't have to go over this with as much power/force hopes this helps
Apr 15, 2014 | Vacuums
Want to use Bissell Pro Heat 2X Clean Shot. Have
You can download a user manual from the Bissell website
Sep 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I need instructions for bissell pro heat 2x cleaner
you can dawnload it from the manufacture,s website.you should go to there and dawnload it.
Sep 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Is the brush on the bottom suppose to automatically spin when powered on?
If its upright the brush will not turn.It only turns when in pushing position.
Jul 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Mar 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell pro heat advantage 12 amp
You can download the instruction manual at the Bissell.com web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
115 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
