Question about Motorola Mobility RAZR V3
Earpiece speaker no longer working
I can't hear the caller on the other end with just the regular earphone. The speaker works OK, so I can get calls, but not privately.
  • Anonymous Mar 13, 2014
    the phone has only just been replaced as took my other one back with same problem when i make call everything comes through the loud speaker and have not even got it on loud speaker only way to have a private call is to use the earphones can i resolve this or is it a fault??
  • 28 Answers
Was the phone dropped or had anyone taken it apart?
Posted on Jan 13, 2009
Incoming calls cant be heard. Caller can hear me but I cant hear them unless I put it on speaker
probably faulty earpiece, try to install SoundAbout and force the phone call audio to the earpiece, if that doesnt work, then the earpiece is brobably broken
Apr 11, 2017 | Cell Phones
Why can I not hear the caller talking when I answer my HTC 7windows phone
This is fault on your earpiece and needs to be replaced ip you can remove the panel and confirm if the earpiece has a continuity or if there was any connection issue.
Finally test using a handsfree to confirm that the board is working well and the fault relates only to the earpiece.
Nov 04, 2011 | HTC 7 Mozart Cell Phone
I can only hear a caller when using the speaker phone otherwise it is like my phone is on mute although they can hear me. Any possible solutions appreciated, not ready to replace just yet.
Hello there,
My dear friend, the problem is simply that the earphone of the bad/ damaged that is why you cannot hear anything on the phone. As long as your caller can hear you but you cannot hear them, then it is confirmed, because, the speaker is on a different side of where the earphone of the phone is.
The solution is just for you to have the earphone of the phone replaced.
But before replacing the earphone of the phone, you can use a bluetooth hands-free temporarily or an external earpiece that you can connect to the phone and be using on the phone temporarily before replacing the earphone of the phone.
Using a bluetooth hands-free or external earpiece is quite cheap and is of easy access.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | LG enV VX9900 Cellular Phone
Can not hear callers and caller can not hear me I hear ring tone I can txt my alarm works just no phone calls
Hi, You will need to replace the earpiece and the mouthpiece.
The earpiece makes you to hear callers when they call, and the mouthpiece allows the callers to hear you when you call.
When you replace the mouthpiece and earpiece,the phone will be normal again.
Take care.
Oct 01, 2010 | Samsung SCH-u740 Cellular Phone
I couldn't hear the voice of the caller wen sumone calls me... bu i can play music player nd use loud speaker. I use nokia 3110c.
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Sep 01, 2010 | Nokia 3110 Cellular Phone
Can't hear callers voice unless phone is put on speaker phone. The built in hearing piece dosen't seem to work? Is this a setting problem
This is not a setting problem, the problem is that the earpiece of your phone is bad that is why you cannot hear callers voice.
The speaker you put it is for the ringer, it does not have anything to do with earpiece and you can hear your caller through it.
To fix your earpiece problem because you cannot be putting your phone on speakers always because atimes you will want privacy.
To fix the earpiece problem, you will need to replace the earpiece on your phone in other for you to hear your caller. just change the earpiece as advice and you will see that the problem is solve.
Take care.
Jun 03, 2010 | Samsung SCH-u740 Cellular Phone
Can only hear callers in speaker mode. When speakerphione is off, DTMF doesn't seem to work and I can't hear the caller, yet they can hear me
hi,
It seems that the earpiece speaker in your phone might be not working.
Before that verify that the call volume is set to maximum while you are in a call. If still problem persists, then you have to check the earphone present in your mobile.
Please provide your ratings.
Thanks
May 26, 2010 | Motorola Mobility RAZR V3
The earpiece and speaker will not work. the other caller can hear me but i cant hear them
Since you said your other caller can hear you but you cannot hear them, it means the earpiece of your phone is bad and will need to be replaced.
Change the earpiece and you can hear your caller easily.
Take care.
Apr 19, 2010 | Motorola Mobility CLIQ Cell Phone
Hi got a Nokia phone, when I mak eor get a call I
Hello, Are you try to say that you cannot hear calls through the earpiece? If that be the case, its either the phone earpiece is bad and you need to change it, or the fault might be from the phone board, that is, you need to reformat the phone with software and this can be done in Nokia shop and any phone repair shop.
You also have an option of using a earphone instead of using the phone speaker because it might be noisy and not very clear.
Take care.
Nov 19, 2009 | Nokia 3110 Cellular Phone
Plugged in headphones for call, now earpiece doesn't work
Same here. I tried many things but cannot ring it back to headset mode. I continuously see the headphone icon shown in the phone, so it seems that the phone thinks that it is still connected to earphones. Sometimes, it works fine, but mostly it does not. If I connect the phone on bluetooth earphones, it works fine.
Any help will be appreciated.
Mar 13, 2008 | Nokia 7370 Cellular Phone
Motorola Mobility RAZR V3 Logo
171 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
