Question about Philips 60P8341 60" Rear Projection Television
Colors glowing to bright
The whites are realy bright and all the medium colors seem to be too dark, but the picture itself would be good if I could tone the bright down.
  • Anonymous Mar 24, 2014
    we can raise the brightness up and parts are still too dark to see where as the white is too bright and everything is blurred around the edges.
    New Friend:
  • 129 Answers
The coolant liquid ,that is inside the picture tube lenses need to be replaced. this helps to keep the internal picture tube temperature cool down. and the focus quality. the cost to replace it could be around 250.00 dependin on the tech . in repair shop 350.00 any questions Jus ask I'm glad to help you
Posted on Jun 12, 2007
SOURCE:
Why does my sanyo dp46848 screen go dark but whites are too bright?
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Jun 30, 2014 | Sanyo DP46848 LCD TV
My tv ,whites glow way too bright,dark colors way to dark,what is wrong
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 08, 2010 | Philips 60P8342 60" Rear Projection...
Picture suddendly changed to "photo
hi! your lcd cpu is defective, here in the philippines we try to re heat the cpu and it works.
Sep 04, 2009 | Insignia 42" Flat-Panel Plasma HDTV
White halo fuzzes the picture on TV
Had the same problem with white glows. Followed the directions in this link and the white glows and color brilliance was fixed.
http://www.avsforum.com/avs-vb/showthread.php?t=1148792
Apr 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Dark picture
you probably have a bad capacitor on the invertor board. try shining a flashlight into it to see if you can see anything. if capacitors are good, you might have some burnt out backlight bulbs. i just had the same problem, replaced the capacitors but messed something else up on the way i guess cause now all i have is a bright white screen with a few colors here and there.
Aug 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
PROJECTION TV Phillips 9P6031c103
this is what convergance looks like;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
if pix is dark their is 6 adjustments knobs in the front of the tv under the screen and behind the plastic cover. the top three are the brightness bottom three is focus.
Nov 24, 2007 | Toshiba 53H71 53 in. Rear Projection...
51 projection tv dark colors
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Philips 60P8341 60" Rear Projection Television Logo
153 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
