Question about Whirlpool DU930PWS Built-in Dishwasher
What's your problem?trobleshooting w10142800b dishwasher control lock broblen
On kitchen aid dishwasher, control lock is blinking and preventing the use of any other execute buttons. Can't start a wash .
Which model KitchenAid dishwasher do you have? On some models, the Control Lock can be toggled on/off by holding the Energy Saver Dry touch pad for at least 4 seconds or until the Control Lock light turns on or off.
On another model, the touch pad to press and hold is the 4 Hour Delay button. (On that model, you press and hold for 3+ seconds.) There is often a very tiny label below or on the touchpad indicating which key controls the Control Lock.
If you haven't held the button for long enough, pressing the other touch pads will lead to the Control Lock light blinking 3 times if the Control Lock is active.
If the press and hold method still doesn't work after several attempts, then you may have a problem with the control panel. The dishwasher may need repair.
I hope this helps. Please add a comment with the model number so that I can check if a different touch pad key is the correct one for the Control Lock.
(the Control Lock feature keeps the dishwasher settings from being changed accidently or the unit started when it isn't needed. This can stop a child from resetting the dishwasher or the unit being started while you clean it.)
Oct 15, 2012 | Dishwashers
Dishwasher won't run. Message says Control Locked.
push and hold the lock button for 3-5 secs then release
Oct 13, 2012 | Dishwashers
Blinking auto lock Whirlpool
What does it say in fine print right under control lock? "Press & Hold"? Page 16 of the user manual shows it as "air dry" with two lights, twelve and three o'clock positions. It says hold it for four seconds and the light turns off.
Aug 20, 2012 | Whirlpool GU1200XTLS Stainless Steel...
Kenmore ultra wash 6651393 control lock light flashing
I would try turning the breaker off for 5 minutes to see if it will reset.
Jun 09, 2012 | Kenmore 15899 Built-in Dishwasher
Whirlpool Gold quiet washplus dishwasher Red Light staying on--control locked Cannot get it to run, no buttons will do anything
Which model dishwasher do you have? The Control Lock is a feature that keeps a child from starting the dishwasher when it shouldn't run. The Cancel button will work but not the Start button.
On the DU920QWD, to toggle the Control Lock off, press and hold Air Dry for 5 or more seconds. (Holding it again will turn on the lock.) Most dishwashers will have a the Control Lock key labeled with text in a small font for how to enable the Lock. The direct link to the DU920QWDB4 manual is https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%203376817.pdf .
For other Whirlpool dishwashers, the Control Lock sequence will be listed in the manual. You can get a PDF of many Whirlpool appliance manuals from http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . Enter the model number (from the rim inside the unit) and click on the right arrow.
I hope this helps.
Sep 08, 2011 | Whirlpool Dishwashers
My VZ9996U1 built-in dishwasher won't lock &
sounds like the door latch is broken, turn off power to unit and remove in side of door, about 20 screws, at th etop of th edoor you will see the latch it will have several wires going to it, you may even find broken parts (PLASTIC ) you can order parts from here http://www.appliancepartspros.com/ they have very fast shipping you just need all the info on the machine
Jul 27, 2011 | De Dietrich 24 in. DVI100 Built-in...
I have GE Profile dishwasher Model PDW9880 series. It will not drain. We had a repair man come & he said it needed a new control board. Do you think this is true? If so, can I purchase one one my...
Of course you can purchase the part. Module runs around $100. Dishwasher control boards are usually easy to replace, but there's no way I can determine if you're capable of doing it.
Jul 14, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
KITCHENAID DISHWASHER SUPERBA MODEL KUDS01DJSS0 CHILDLOCK DOES NOT OPEN .REMAINS IN LOCKED POSITION EVEN AFTER POWER RESET. CAN'T USE THE DISHWASHER.
The easy solution is to try pressing the Energy Save Dry button & hold it in for 3-5 seconds. This should turn the child lock on & off.
If this doesn't work, then it's likely that one of the pads on the control panel is stuck, and it (the control panel) will have to be replaced.
If you don't have the manual, you can download one here (PDF format). Good luck!
Mar 02, 2011 | Dishwashers
The control lock light goes on as soon as I press the cycle to start the dishwasher. The dishwasher does not start, presumably because the control lock stays on. I do not know how to disable the control...
Hello & Welcome to FixYa
To unlock the controls press and hold the HEATED DRY button for 20seconds. If the problme returns then only option is touch pad replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Maytag Dishwasher
My dishwasher seems to be locked up and needs to be reset. the clean led is constantly flashing. i had this trouble in the past, and the serviceman reset the dishwasher by using the touchpad on the front...
Control is programmed to
stop the current cycle and
not allow any further
cycles if it suspects a
faulty heater (no
temperature increase
detected in heated
intervals). Control blinks
the Clean LED 7 times in
repetitive fashion and
disables the Start/Resume
key until cleared.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater
circuit.
■ Faulty heater drive
circuit on control.
Running Diagnostics clears the control and
allows it to operate again. If heating problem
is not corrected though, the control will stop
running again on next cycle. See below.
1. Unplug dishwasher or disconnect power.
2. Check all components and connections in
the water heating circuit or heat dry circuit.
■ Check resistance of heater.
■ Check resistances of all connections and
components between the control and
heater.
■ Check operation of heater and temperature
sensor in Diagnostics cycle.
Aug 26, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool DU930PWS Built-in Dishwasher Logo
371 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
