Question about Sherwood R-945 Receiver
Sherwood R-945 NEED CIRCUT DIAGRAM OF OUTPUT AMP
Is the Phono output on the RX4109 considered a preamp output in to a Power Amp?
The phono connection is an INPUT and it is a low impedance circuit. It is easily overdriven because the signal that goes into it is very small. You plug a record player into it. Any pre-amp connections on an audio device are in place after equalizer controls. There are no pre-amp connections on the Sherwood.
Sep 13, 2014 | Sherwood RX-4109 Stereo Receiver Black
Does the sherwood rx 4105 receiver have analog or digital inputs
Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
Feb 12, 2013 | Sherwood RX-4105 Receiver
My powre subwoofer in not working with the sherwood r-945. Can you help.
I assumed that your receiver has a SUB RCA jack on the back..
find out the SUB output 1xRCA plugs of your receiver on the back and connect it to the 1x RCA input of your Sub...you just need a RCA cable .
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
If you need more help please contact me...with more detailed question..
Regards
Jun 22, 2011 | Sherwood R-945 Receiver
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Hear sound but cant get any real volume even at full blast
I was playing around with my Sherwood RD 6513 and adjust the the output level to its maximum, amongst other settings. This limited my output on the amp to a maximum volume of 65 not 90+.. Anyway i pluged in the microphone and done another 'auto setup' of the volume levels and distances, and this allowed the volume to exceed 65 again!
Also if you have an external source such as a DVD player - i would assume you have already checked its output volume setting?
Nov 23, 2008 | Sherwood RD-6500 Receiver
What is an output transistor?
output tranisister is the transister that give the finial output of sound.
some use a output IC for the same purpose.
Aug 31, 2008 | Sherwood R-945 Receiver
Sherwood R-945
HAI , REPLACE THE VOLUME CONTROLS.
Jun 26, 2008 | Sherwood R-945 Receiver
No power
The Sherwood R-945 has at least 6 fuses inside - any one of them could keep the system from powering on properly. The lowest power fuse is rated at only 35 MILIamps, I believe ( it's element is barely visible to the naked eye ). Check that all fuses are intact (with the power off)
My R-945 unit kept shutting itself off directly after powering up - turned out that one of the speaker wires had a fault - (found after hours searching with voltmeter). Check that all Inputs / Outputs are secure.
Good luck with yours!
Feb 20, 2008 | Sherwood R-945 Receiver
No power
disconnect everything from the unit and see if it still does it.
if it does i would check the output transistor (ic).
Jan 25, 2008 | Sherwood R-945 Receiver
Sherwood R-945 Receiver Logo
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
