Question about Bryant 462AJC021BA Air Conditioner
How old is my outside heatpump
Model # 661cj048-a serial # 2397e04509
    Sergeant:
  • 340 Answers
1997 second set of digits in the serial# . Tom
Posted on Jun 21, 2009
    Guru:
  • 462 Answers
1997 (23rd week of 1997) 1set number week 2nd set year.
Let me know if this helps you and please rate me as high as you can. Thanks for using fixya and good luck.
Posted on Mar 25, 2009
I have a 12 year old RUUD heatpump model UJMAA048JK-549 that repeatedly trips the "High Head Pressure Limit" switch at 30 degree temperatures but works fine when the temperature isn't as cold. Is...
ONLY 3 THINGS WILL CAUSE THIS
1) CLEAN THE OUTSIDE COILS WITH A COIL CLEANER AND A HOSE
2) THE FILTER IS DIRTY
3) THE UNIT IS OVER CHARGED
IS THIS A SPLIT SYSTEM OR A WINDOW UNIT THE MOST LIKELY ARE 1&2
Feb 06, 2011 | Ruud Heating & Cooling
Where is the capacitor located on a coleman heatpump
If you're talking about the outside fan, look where the wire goes into the outside unit. The capacitor will be somewhere near the circuit board and will be round or oval and metal or plastic. If you're talking about the inside unit it will be with the electrical control in the air handler. Write down where the wires go. The terminals on the capacitor will be marked and for the outside unit you will either have 1 that runs both the fan and compressor or a seperate one for each. If you have 1 that runs both the wires must be reconnected to the right terminals. They will be marked COM, FAN, HERM(stands for compressor). Take the old one with you to get a new one. Let me know what you find.
May 04, 2010 | Coleman Heating & Cooling
2005 s type jag a/c quit blowing cold air suddenly .just blows hot at any setting or on auto
hi,is this a heatpump or a ac unit only...if a heatpump ,there is a valve that switchs from heat tocool mode...go outside with unit running..put hand on big copper line,if it is hot your in heat mode..if cold your in cool mode....possible stuck change over valve if a heatpump...hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...if need more assitance..call..its free...good luck
Mar 26, 2010 | Heating & Cooling
Rudd heatpump compressor runs outside fan dose
I don't think the fan on it' own crates the problem. Could you find out what should be and what actually is the flow through it. If you needed <!-- MOJAIZBA.COM LINK CODE START --> <a href="http://mojaizba.com/convert-units-of-flow" title="Flow units converter page on mojaizba.com - Convert flow units online. Use the calculator for making conversions from one flow unit measure into another flow-volume amount between; acre foot per: acre-ft/day, hour acre-ft/hr, year acre-ft/yr, bar/day barrel Oil per day, hour bar/hr, minute bar/min, second bar/sec flow, cubic centimeter per day cm3 / day, hour cu cm/h, minute cm3/min, second cm3/sec flow, cubic foot feet per day ft3/d, hour ft3 / hr, minute ft3/min, second cuft/sec, cubic inch per day in3/day, hour in3 / hr, cubic inch per minute cu.in/min, in3/sec, cubed meter per day m3/day, hour cu m/h, minute m3/min, second m3 / sec, cubic yard per day yd3/day, hour cu yd / h, yd3 / min, cu-yd/sec, gallon US gal/day, gal/h, gal/min, gal/s, gallon UK per day gal/d, gal/hr, gal/minute, gal/sec, hundred cubic feet foot per day 100 cu-ft/day, 100-ft3/hr, hundred cubic foot per minute flow 100ft3/min, 100 cubed ft/sec, kilogram per day - Petrol kg/day, hour Gasoline kg/h, kg/min, kg/s, liter per day l/day, l/hr, l/min, l/sec, milliliter per day ml/d, ml/h, ml/min, ml/sec flow, ounce US per day oz/d, oz/h, oz/min, oz/s, ounce UK per day oz/day, oz/hr, ounces/min, oz/sec, pound per day - Petrol flow lb/day, Gasoline lb/hr, lb/min, lb/sec. USA – Imperial UK and Metric SI system units of flow. Buy the JavaScript JS and HTML code for this web flow converter tool application for your website." target="_blank">flow units converter</a> <!-- MOJAIZBA.COM LINK CODE END --> for a unit you'are comfortable with here is one we use if it's necessary. Let me know that...
Mar 21, 2010 | Ruud Heating & Cooling
Thermostat Wiring Problems!!!
. your blue is probably common and if you hooked it to Y you shorted the transformer or blew the low voltage fuse. Green is fan, yellow is AC, Red is 24volt. Is it a heatpump or just ac? I think its probably a heat pump and your brown is your Reversing valve it needs to be hooked to O on the new stat. If its a heatpump your tstat must be a 2heat 1 cool stat w/ aux heat. Without knowing what terminals the wire were hooked to on the old stat you may have to look at whats hooked up at airhandler( furnace) and on A/C (heatpump) tobe able to determine what goes where on the new one.
Sep 20, 2009 | Heating & Cooling
Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
May 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman heatpump. Crazy pressure in heat mode
Check the TXV valve on the outdoor unit, it could be stuck closed. We have been experiencing the same problems with the 410 systems and the TXV was the culprit. Good Luck
Dec 19, 2008 | Goodman CLQ36AR49 Air Conditioner
I'm having a problem with my heating and air system, my heat only works on emergency heat ( and run 24/7) if i turn it to regular heat it only blows cold air. i dont think my outside unit fan is turning( i...
If your Heatpump's fan isn't running but your compressor is, your fan motor is out. If nothings happening at all ensure your getting power to heatpump (ex: breaker tripped, fuses blown on outside power switch, or fuses blown in breaker box?)
Dec 04, 2008 | Heating & Cooling
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Bryant 462AJC021BA Air Conditioner Logo
507 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
