Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Can't change stations
This problem happened a few days ago. I can turn the TV on and off but cannot change the station or the volume. Neither the remote nor the buttons on the TV itself work (except for Power). The one station that does work comes in fine. I do not have cable, I only use the over-the-air signal. I tried unplugging it overnight but this did not help. Panasonic support only referred me to a repair shop. Any ideas would be appreciated. Thanks, John
  • 934 Answers
John, That would be my recommendation also.. Sounds like the micon controller IC or some breakdown on the video systems board. A shop would be equipped to scope the various wave forms according to board schematics. Something you're probably not able to do unless you have at least a 20mHz scope, a signal generator and some other fairly expensive and complicated equipment. What I can help with to further the suggestion is that you take it to the shop yourself, that will save a few bucks - and if you're not sure on where to begin researching a reputable shop try the NESDA web site at: http://www.nesda.com/locator/state_search.php Sorry, as a certified tech it's my least favorite part of the job handing out an opinion you probably didn't want to hear. Good Luck Bill
Posted on Jun 12, 2007
SOURCE:
Fuel troubleshooting
U may have got some bad gas maybe with water in it. Check with service station to see if anyone else had a problem that day. This happen to me a few years ago and service station paid for my repair.
Apr 18, 2014 | 2001 Mitsubishi Diamante
Radio Station Keeps Changing Automatically
hi there is a option in the settings to automatically search for the station if frequency changes try turning it off to see if that helps
Mar 23, 2014 | 2006 Hyundai Accent
I have a 19 inch Vizio HDTV hooked up to cable. It has worked beautifully until two days ago when 3 stations all of a sudden began speaking in Spanish and 3-4 stations (different) audio went mute. This all...
In the audio menu there is a setting for "SAP". This stands for Second Audio Program. Some stations will broadcast a SAP signal along with the normal signal. Some don't, That is why some stations don't have any audio. Turn that SAP off.
Oct 14, 2009 | Televison & Video
My Visio turns itself off and on when I change to one channel
I had the same problem. Tech support told me to turn the tv off, then unplug it. Then hold the power button (on the tv - on the bottom of left side) in for 30 seconds and try again. This did solve my problem.
Jun 14, 2009 | Vizio VW32L 32 in. LCD HDTV
My 32" Toshiba LCD HDTV keeps freezing on the same channel and when I try to change the channel or input selection, it doesn't respond(to the remote or directly on the TV.) The only thing that works is...
These problems are normally caused by the TV station.
1. Call the TV station responsible and ask for the network engineer.
2. Tell him the Day, Time, Channel, Program, basically every little detail about the problem.
3. The station will normally check it and fix it.
Also, contact Toshiba and tell them. Really this is part of the DTV Transition thing. Many stations are reconfiguring and settin up equipment. They sometimes make mistakes. Don't worry much about it unless it continues for more than a week. If you like the station, I would call right away.
May 25, 2009 | Televison & Video
Weather station giving wrong outdoor temperature all of a sudden
check if you have the US standard or international standard, like FD. or CD...........
and check your pda the loation where you set is right.
and try to reset a new website for your PDA weather software for updating. becasue different websites may be vary
Jan 10, 2009 | Computers & Internet
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
