Question about Razor MX350 DIRT ROCKET - BLUE
Having trouble putting new rear wheel assembly on mx350 dirt rocket
  • 53 Answers
The user manual for the Razor MX350 is available on the web.
here
http://manuals.monsterscooterparts.com/recreational/Razor/
it shows how to remove/install the rear wheel.
Posted on Oct 24, 2013
3 Suggested Answers
SOURCE: Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
Posted on Nov 03, 2010
  • 368 Answers
SOURCE: I have charged my MX
The battery is probably bad. If a battery is fully discharged it can damage one of the cells in the battery. If you can replace the bad cell then it should charge correctly. Many of these batteries are made to be hard to open up and are hard to repair when they are opened. My best solution is to replace the battery and if that doesn't help then the charger is bad. When the charger is replaced then if both batteries are good then you will have a spare. I hope this helps.
Posted on Aug 16, 2011
Razor MX350 how to reattach kickstand spring
Hi, Jerry for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Tips for changing kickstand spring Harley Davidson Forums
Removing and Replacing Kick Stand Springs
http://www.marathonandmore.com/mini-moto-dirt-bike-service-manual.pdf
Razor MX350 Dirt Rocket Parts
Razor Dirt Rocket MX350 Owner Manual
Sep 10, 2017 | Razor MX350 DIRT ROCKET - BLUE
Tighten chain
Loosen both rear axle nuts, pull wheel back but keep it straight in the frame. retighten bolts
Sep 10, 2014 | Razor MX350 DIRT ROCKET - BLUE
Razor mx350
Have you tried removing plastic chain guard and making sure chain is not off track i had this problem and that is all it was.
Apr 24, 2014 | Razor MX350 DIRT ROCKET - BLUE
The bike after charging is going very slow, not full speed! What could be the problem? MX350 Dirt Motorcycle
could be a faulty battery charger not putting out the right amount amps,or battery could be going out.
Aug 07, 2011 | Razor Dirt Rocket MX350 Miniature Electric...
Need rear wheel assembly instructions
Please go to:
http://www.razor.com/$assets$/26c3c2bb-d15e-4531-9157-70ec1128fb5b/MX350
Jul 09, 2011 | Razor Dirt Rocket MX350 Miniature Electric...
How do i change the rear tier of my razor mx350?
I would take it to a shop only because the tire has to be on almost perfect so there is no wobble.They have the proper equipment to make sure it is aligned properly.If you are going to go around 40-50 mph alignment is critical.Even jumping moguls and turning alignment is critical.
Jul 22, 2010 | Razor MX350 DIRT ROCKET - BLUE
Razor MX350 DIRT ROCKET - BLUE Logo
122 people viewed this question
Top Razor Cycling Experts
Ted Maxwell
ray gallant
wayne-m
Are you a Razor Cycling Expert? Answer questions, earn points and help others
