Question about Razor MX350 DIRT ROCKET - BLUE
Changing rear wheel assembly on mx350 - Razor MX350 DIRT ROCKET - BLUE
  • 53 Answers
How to change rear wheel bearings
25317835-3udur2h4av2xrpdnawrm5shi-5-0.jpegRemove wheel,brake caliper & bracket,disconnect speed sensor & remove hub wheel bolts (Wheel bearing/hub is an assembly)
Dec 11, 2014 | 2004 Mini Cooper
Tighten chain
Loosen both rear axle nuts, pull wheel back but keep it straight in the frame. retighten bolts
Sep 10, 2014 | Razor MX350 DIRT ROCKET - BLUE
Razor mx350
Have you tried removing plastic chain guard and making sure chain is not off track i had this problem and that is all it was.
Apr 24, 2014 | Razor MX350 DIRT ROCKET - BLUE
Having trouble putting new rear wheel assembly on mx350 dirt rocket
the user manual for the Razor MX350 is available on the web.
here
http://manuals.monsterscooterparts.com/recreational/Razor/
it shows how to remove/install the rear wheel.
Dec 12, 2012 | Razor MX350 DIRT ROCKET - BLUE
My Dirtbike, wont go after i charge it
Check that the lights on the throttle battery gauge show green. Lift the rear wheel off the ground and apply throttle and watch the lights. If the battery voltage drops under this load, indicated by the light changing to yellow or red, then it is likely the batteries are low in capacity and need replacing. Most battery shops will load test the batteries free of charge to confirm.
If the batteries test OK then it may be a bad connection between the batteries, fuse, switch and controller may also cause the voltage to drop under load,
Oct 15, 2012 | Razor MX350 DIRT ROCKET - BLUE
Rear wheel bearing 2002 toyota hihlander
On front wheel drive models, the rear hub bearing is an assembly that bolts to the spindle.
Not sure about AllWheelDrive models.
Jun 29, 2012 | 2002 Toyota Highlander
Need rear wheel assembly instructions
Please go to:
http://www.razor.com/$assets$/26c3c2bb-d15e-4531-9157-70ec1128fb5b/MX350
Jul 09, 2011 | Razor Dirt Rocket MX350 Miniature Electric...
How do i change the rear tier of my razor mx350?
I would take it to a shop only because the tire has to be on almost perfect so there is no wobble.They have the proper equipment to make sure it is aligned properly.If you are going to go around 40-50 mph alignment is critical.Even jumping moguls and turning alignment is critical.
Jul 22, 2010 | Razor MX350 DIRT ROCKET - BLUE
1992 Honda Accord EX Replacing the Rear Wheel Assembly
It won't make any difference, seeing that the car is older and you don't have the ABS functionable it won't change anything. You already have the ABS light on so nothing new will happen.
Regards
Sam
May 05, 2009 | 1992 Honda Accord
Razor MX350 DIRT ROCKET - BLUE Logo
82 people viewed this question
Top Razor Cycling Experts
Ted Maxwell
ray gallant
 steve
steve
Are you a Razor Cycling Expert? Answer questions, earn points and help others
